Author Topic: A Little Help on Technique  (Read 3052 times)
« on: October 20, 2008, 03:13:16 PM »
I need to know what's the best way to play the following without throwing my guitar out the window. Like pick direction, etc. I play it a certain way but it's a bit fiddley and thought someone could show me some way it could be easier. Who knows, I could be right, but just wanted a second thought on it.
Thanks.
Code: [Select]
C#||--17-------------------------------------
G#||-----18-------18-------------------------
E ||--------19-------19-------19-------------
B ||-----------19-------19-------19-------19-
F#||-----------------------20-------20-17----
B ||-----------------------------------------
-----------------------------------18-------1
-----------------------19-------19-------19--
-----------20-------20-------20-------20-----
-----17-20----17-20-------20-----------------
--20-----------------------------------------
--17----------------------15-----------------
-----18-------18-------------17-------17-----
--------19-------19-------------18-15----18-1
-----------19-------19-----------------------
-----------------------20--------------------
--13----------------------12------------------
-----15-------15-------------14-------14------
--------15-14----15-------------14-------14---
--------------------15-12----------14-------16
Matt77
Re: A Little Help on Technique
« Reply #1 on: October 20, 2008, 04:54:49 PM »
17---13
Matt77
« Reply #2 on: October 20, 2008, 05:00:34 PM »
oops slipped on the keyboard !!
I would def play the 1st bit as a d minor arpeggio in 3 different inversions on the E-B and G strings so the picking is all the same. Down up,up,up.
I'd play:
--17--13             --13--10           10--5
             --15                   --10              --6
                   --14                 --10               --7
What song is it and who by?
Ben_W
« Reply #3 on: October 20, 2008, 06:24:57 PM »
I'd personally probably sweep pick it, and hammer on/pull off the notes on the same string. Although if it was a bit slower, i'd probably just do all up strokes, but a down stroke on the 19th fret on the B String to get back up.
C#||--17----------
G#||-----18-------
Cold Sweat, Irish Tour, Miracle Man
Matt77
« Reply #4 on: October 20, 2008, 10:38:45 PM »
You could also play it as a 2 notes per string, string skipping lick, Paul Gilbert style. That would probably sound good
« Reply #5 on: October 20, 2008, 11:06:05 PM »
I'd sweep it.
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #6 on: October 21, 2008, 04:27:13 PM »
Alternate pick it you wusses.
I see a rainbow rising
Look there on the horizon
And I'm coming home
Jamie
« Reply #7 on: October 21, 2008, 10:37:58 PM »
Yeah id find it a lot easier to alternate pick.
Kevin Bond sig RR Jackson        Charvel SoCal
Ibanez Jem BSB                       Jeff Loomis Sig 7 String
Warmoth Strat                         ZW Bullseye Epi
Orange #4 TT and Cab
« Reply #8 on: October 21, 2008, 10:39:21 PM »
I sweep it, it's just the transition between sweeping up and down.
