Author Topic: marshall 20/20 or other 1U power amp?  (Read 8083 times)
« on: October 30, 2008, 08:12:50 PM »
i'm in the market for a 1u rack power amp. it doesn't need to be stereo. is the 20/20 any good, or is it a bit lacking in tone? is there other stuff i should be looking at?
open to considering solid state if good sounding, though obviously it will be used for guitar. does it need to be a dedicate guitar power amp, or can i use a studio power amp? it will be driving guitar speakers at the end.
thanks...
« Last Edit: October 31, 2008, 05:47:30 PM by gwEm »
Re: marshall 20/20 or other 1U power amp?
« Reply #1 on: October 31, 2008, 11:46:03 PM »
Well since you have got no responses...
I looked into one a bit back, and there seems to be HUGE overheating problems, it has to have a clear rack space either side, and the cover needs extra vents.
Also is only stereo, not dual monobloc as the EL34  versions are.
« Reply #2 on: October 31, 2008, 11:58:36 PM »
Was the Mesa Boogie 20/20 any better?
« Reply #3 on: November 01, 2008, 05:48:23 AM »
thanks...
If you can go SS without losing major sound aspects depends also on the preamp that drives it. I am using SS because my preamp (AxeFX) has on/off switchable power amp simulation, which considers all aspects of a tube power stage (sag, 3D-ness, punch, transformer impact, etc), but this is rather unusual or even unique.
If your current rack doesn't allow for another 2U, I suggest to sell it and get a bigger one. Rackspace should not dictate what you get, it should be tone vs price?
« Reply #4 on: November 01, 2008, 01:35:42 PM »
thanks...
it doesn't have the power stage simulation. i hope to make a post about my preamp later
Quote
its more a question of size, and how much i can carry. sort of assumed that a 1u would be lighter. don't have a rack case so far, so maybe one option is to check the weight of these things.
« Reply #5 on: November 01, 2008, 01:36:40 PM »
thanks will. i read this on harmony central also, but some people are disagreeing and saying its really reliable etc etc. there seems to be a question mark over it though as you say
« Reply #6 on: November 01, 2008, 02:32:03 PM »
Gwem - Theres a guy near you in Shoreditch selling a Boogie 2U hight 50w a side power amp
Has an advert up for it on Gumtree
I know cause he's also got an Egnater preamp up for sale
(was why `I asked you about Shoreditch the other day)
Brow
« Reply #7 on: November 01, 2008, 04:31:15 PM »
I have a 20/20 in a 4u rack and had no problems at all with it so far.
I've heard the problems about over-heating etc, but it has a rack space above it empty and it seems ok so far :)
1 thing I don't like about it is that it's always stereo (as mentioned above). What I do when I want to run it in mono is to use my Weber Mass on the 2nd output without plugging it into a cab. As it sees a speaker load by doing this I don't think it should cause any problems.
« Reply #8 on: November 02, 2008, 02:08:31 PM »
it should also be possible to physically remove the EL84s and phase inverter from one of the channels i suppose to use it in mono.
do you like it as a power amp brow? in terms of the sound?
Brow
« Reply #9 on: November 02, 2008, 03:29:10 PM »
I have no idea about removing the other valves and phase inverter, bit technical for me, but the Weber mass things works for me so far :)
As regards the sounds, I really like it for clean, crunch and mid level ODs, but haven't been able to dial in much I like for higher gain stuff so far. Whether thats because I'm used to the sound of EL84 amps for clean/crunch and not high gain I don't know. I need to sit down with it at a decent volume level and give it another go :)
