Author Topic: How does winding influence the sound?  (Read 6181 times)
« on: September 26, 2005, 04:52:21 PM »
I'm guessing different windings can offer very different sounds. The Crawler and the Riff Raff are both AV PAF based pickups but each has a very different sound. The same goes for the Miracle Man and the Cold Sweat. I've heard more winds equals more mids. But there must be more to it than that. How does the winding shape the sound?
Davey
« Reply #1 on: September 26, 2005, 05:28:47 PM »
everything is in the winding.
two on the outside identical pups can sound like night & day once you plug em in
talked about diferent voicings with steve made possible with just winding.
example: ibanez powersounds are machine wound exactly straight. thats why they sound like pure cr@p. custom and butique pups wound by hand utilise scatterwinding quite a lot and emphasize layering of winds throughout the bobbin, making diferent voicings, mid humps, trebble bumps and bass tightness possible
(no, i didnt talk about this wiht steve from BKP.. it was Steve Vai ;))
« Reply #2 on: September 26, 2005, 07:05:23 PM »
Scatterwinding in particular increases the average distance between turns so lowers the distributed capacitance and raises the resonant peak of the pickup.
In addition exactly parralel winds leads to mutual inductance between turns and a more brittle sound.
All told you can make very powerfull pickups that still sound clear and very bright pickups that arent piercing
As far as specific widing patterns making particualr tones goes, sure enough it does, but thats the black art of BKP and all those like it!
Tim
  • BKP
« Reply #3 on: September 26, 2005, 09:08:09 PM »
It's not just in the wind, it's the wire gauge and type along with magnet choice too.Even pole shoe, slug and pole screw material have a huge effect on tone...........baseplate and covers too.
It's like all things............try to skimp or do things too quickly and the tone suffers.Patience and attention to detail are crucial in winding pickups.
Tim
big steve
« Reply #4 on: September 26, 2005, 10:15:04 PM »
not to mention chanting incantations, ritual dress, the odd seance...
« Reply #5 on: September 27, 2005, 04:59:54 PM »
Thanks for all the info. I was asking because I'm trying to figure out what the possibilities are for the GFS Retrotrons in my Dean Psychobilly.
From what I can tell by looking at it, the baseplate is similar to that of a SD pearly gates. The coils are about the same height too. Soundwise it has some similarities too. The difference is that it has a ceramic magnet. The ceramic magnet replicates the bite, snarl and attack of a Filtertron to my ears. It also has a dual screw coil. Others have said it's very similar to Kent Armstrong's Kentron.
I would describe the pickup as a mix between a late '70's, early '80's distortion pickup and a Filterton. I like the idea but would like some more sweetnes and growl. It also tends to get a bit muddy on the upper frets. I'm thinking Setzer's sound on the 'Rumble in Brixton' DVD on steroids. :twisted:
Can it be done?
HJM
« Reply #6 on: September 27, 2005, 05:11:30 PM »
Send to Tim for a rewind??
« Reply #7 on: September 27, 2005, 05:14:48 PM »
Quote from: HJM
That is the idea. As soon as I have to change strings on the guitar and if my next paycheck is good enough.
Tim
  • BKP
« Reply #8 on: September 27, 2005, 08:26:52 PM »
I've done several in the past few months and I can sweeten them up no probs!!
Tim
big steve
« Reply #9 on: September 27, 2005, 09:56:02 PM »
Ratrod, why do you know what the baseplate of a SD pearly gates looks like?
« Reply #10 on: September 28, 2005, 03:07:39 PM »
Quote from: big steve
I owned one. It was in the bridge of my customized Tele I recently sold. The baseplate and the coils look very similar on the outside.
« Reply #11 on: September 28, 2005, 03:15:45 PM »
Quote from: Tim
Tim, what kind of winding are you thinking about? 42 gauge plain enamal wire? Riff Raff style winding or Mule style winding? I like the growl of the Riff Raff but also the sweetness of the Mule.
