Author Topic: New valves?  (Read 4055 times)
Ben_W
New valves?
« on: November 04, 2008, 04:27:24 PM »
Hi guys,
I am debating on whether I should re-valve my peavey valveking head.
I don't use it that much now, but it'd be nice to have it incase my current amp breaks or whatever, or i need a spare amp.
I was thinking of putting EL84s in it, and perhaps EL34s to power it?
My knowledge of valves isn't great, so I may have just made no sense whatsoever. But what I reckon my main point i'm trying to say, is that is it worth me re valving it? Will it make a considerable difference? I don't mind paying 100 quid or so and getting a much nicer amp, although if the difference will only be slight, there isn't much point, as it wasn't an expensive amp at all really, which was why I was thinking that replacing the valves may make a large difference.
If anyone can shine some light, i'd appreciate it.
Cheers,
Ben.
Cold Sweat, Irish Tour, Miracle Man
Spitfire
Re: New valves?
« Reply #1 on: November 04, 2008, 04:41:15 PM »
i dont think its worth spending that much money on an amp like a valve king.
Fender Telecaster
Jackson KV-4
Starfield SVA-1
hamfist
Re: New valves?
« Reply #2 on: November 04, 2008, 04:54:41 PM »
Unless one or more of your valves are knackered, then you won't notice a huge difference.
  if it was me, I wouldn't throw money at a Valve King, but save it for something else.  It sounds like the VK is still a serviceable backup, in case your main amp goes down.
f.sardis
Re: New valves?
« Reply #3 on: November 05, 2008, 02:02:12 AM »
been there done that and i can tell you it would be alot better if you spend your cash on a new speaker. what speaker is up to you but be sure to match the ohm.
Ben_W
Re: New valves?
« Reply #4 on: November 05, 2008, 02:44:22 PM »
Well I don't use the VK cab, I have a Marshall I use.
And ok, it seems it won't make much difference, so I won't bother. :)
Re: New valves?
« Reply #5 on: November 05, 2008, 05:34:35 PM »
Hi guys,
Cheers,
Ben.
You would be putting 12AX7/ECC83 in for the preamp and EL34s for the power amp
Hope that helps
Re: New valves?
« Reply #6 on: November 06, 2008, 09:57:10 AM »
A new speaker will make much, much more difference.
Get a G12T in there to brighten and tighten it.
Ben_W
Re: New valves?
« Reply #7 on: November 07, 2008, 06:17:12 PM »
I already have in my marshall cab... :)
