Author Topic: I think I left the GAS on....  (Read 7623 times)
« on: November 06, 2008, 09:52:43 AM »
So many things to buy...so little time...
I need (yes NEED)
Peters chimera
Stupid exchange rate and canadian amps trading in USD sounding so good and no one having anything less than glowing to say about them. I have a PB, of course, and cant really play it loud in the house (old couple next door that have been nice enough not to ask me to turn down yet) but supposed to sound really good low, too
One of those isolation boxes you can plug an amp into. I forget the name. And a new speaker for it.
I'm sick of modellers....and yet.....
AxeFX
Probably more practical, but I'm rapidly losing faith in modellers, no matter how supposedly good. The clips arent setting the world on fire, but I'd get more use from something I can DI than another head....but I'd probably still end up hating it
IK Multimedia ARC
Stupid uneven low end in my studio (I should say "studio", really, its not a proper studio - entry level project studio, perhaps) -  its not too bad (a wise man once told me that 90% of acoustic problems can be solved with speaker location - thanks TO) but I'm still getting lumpiness in the lows.
Really Nice Compressor
For tracking bass. I cant play an even bass track with a gun to my head.
New CD player
My arcam CD73 is utterly wasted on the mediocre B&W DM602s I currently have it through. I want to get it into my RME and Adam A7s again - that sounded STUNNING. But that means I need a new CD player for the lounge
New Hifi Amp
for the new CD player - my nad is going with the arcam to the "studio" and some new speakers I'm getting soon (a gift of some KEF floorstanders!)
Soooooooo
Suggestions on priority, please!
What order would you get these in?
« Last Edit: November 06, 2008, 09:54:56 AM by MDV »
hamfist
Re: I think I left the GAS on....
« Reply #1 on: November 06, 2008, 11:10:10 AM »
Hmmm.  I'd go for the Peters first. Everything else surely has to come trailing along behind that somewhere !
« Reply #2 on: November 06, 2008, 11:51:10 AM »
See thats what my instincts tell me!!
But its the least practical, yet most awesome of those things.
Oli
« Reply #3 on: November 06, 2008, 01:17:36 PM »
For the compressor, i'd suggest the TL Audio 5021, sounds heavenly with bass. I'll try and get a sample up of before/after, as i recently used one on it. I'll suggest getting a SansAmp Bass Driver DI too, as you can get some really good sounds out of it, and it's got a good DI built in, which the TL is missing.
With your speaker positioning, you want them to be 60 degrees from you, and there to be equal distance between yourself, and the speakers (so you have an equilateral triangle formed). Pay attention to how close to the wall/corners the speakers are- close to a wall, you'll get +3dB in the low end, in the corner, you'll get +6dB, and if it's in the corner on the floor (or on the ceiling), then you get +9dB. Also, being close to a wall, will factor in natural resonances from the material of the wall, which will help create this lumpiness. I'd suggest doing some analysis (you can get some software to use with a mic to check the rooms performance- it's not as accurate as a proper acousticians survey, but it's good enough for home), and once you've done your best, just be aware of what the problems are; having a bad room doesn't create a bad mix, not knowing that you do, does :)
I don't know about the order of the rest of things, but personally, the axefx would be at the bottom, i don't want a  modeller :)
« Reply #4 on: November 06, 2008, 02:35:46 PM »
Thanks for the compressor recommendation. I'll need some convincing that its better than the RNC though.
And, thanks, but I knew all that about speaker location already (except you should know that those are rules of thumb, on the amplification of lows, and vary with room), and have the EQ of my listening position mapped out from 40 to 500 hz pretty well - its all +/- 1 to 3db bar a 5 or 6 db hump at 128hz or so thats really hard to suppress with location of the speakers (because its the main resonant mode of the room). It averages to pretty level, but there are too many fluctuations for my liking.
P.S. You missed out centralising the speakers in the room with symmetrical reflections (if you cant attenuate them, which I plan to do (rockwool is your friend)) so that you dont get an imbalanced stereo field.
« Last Edit: November 06, 2008, 02:37:36 PM by MDV »
« Reply #5 on: November 06, 2008, 02:36:56 PM »
save your money, wait a year, and buy a house for about £300. EDIT: that's clearly an exaggeration, but if you can get in right at the bottom of the market you could get a bargain. though the massive interest rate cut might affect that.
« Reply #6 on: November 06, 2008, 02:57:24 PM »
Good theory, save that I dont want to buy a house, and if I did I wouldnt go in at the bottom of the market ;) (not that far above though!)
opprobrium_9
« Reply #7 on: November 06, 2008, 05:24:58 PM »
What is this Peter's Chimera you speak of? (I've gathered that it is an amp, but beyond that...)
« Reply #8 on: November 06, 2008, 05:42:00 PM »
Axe FX and never look back!
« Reply #9 on: November 06, 2008, 05:42:29 PM »
Where would yo usave the money for it though? In a.. BANK?!?!?!
Not me ;)
« Reply #10 on: November 06, 2008, 06:40:04 PM »
Interesting
Why?
Opp, the peters chimera is the Chimera model of Peters amps, as the name suggests!
  • Truly bad since 1972
« Reply #11 on: November 06, 2008, 06:43:32 PM »
*L* keep looking at stereo gear again..loved the arcam and audiolab stuff I had, also the RTL TDL3's speakers but is a bit old now......then I go I buy another amp or Guitar
« Reply #12 on: November 06, 2008, 08:27:14 PM »
by bottom of the market i meant when the prices hit rock bottom, not necessarily buying a cardboard box. :lol:
from what i hear, in certain parts of the USA where there have been loads of foreclosures, you can buy houses for about $1000. :o
obviously if you don't want to buy a house, that's fair enough. :) i'm not too well up on the rest of the stuff you're looking at, i can't really advise there... :lol:
« Reply #13 on: November 06, 2008, 08:37:59 PM »
Interesting
Why?
because it sounds amazing and eats Peters' for breakfast :O)
« Reply #14 on: November 06, 2008, 09:50:31 PM »
Interesting
Why?
Thats fightin' talk!!!
Sorry dave, cant comment on houses, theres fightin' talk afoot!
Do you have some non-I-just-got-an-axefx honeymoon descriptive and comparitive statements to back this up, hunter old buddy?
