Author Topic: Why is nothing ever simple?  (Read 6321 times)
Simon D
« on: November 16, 2008, 08:27:55 PM »
Changed the strings and pickup rings on my Warmoth yesterday. Simple, straightforward job, you'd think? No. Not really, in this case. Took the strings off, started cleaning the neck, gently brushed the cloth I was using against the nut...and the nut popped off.
So, I consulted the big book of guitar maintenance, and glued the nut back on. Then, when I turned the guitar over to put the strings in, I realised that the saddles on the Wilkinson hadn't been clamped down properly (when the guitar was built), and the bloody saddles all moved. So it now needs to be reintonated, which I couldn't do yesterday, because the book said to leave the strings well below concert pitch while the glue sets on the nut. So, so far a 30 minute job has taken about 3 hours.
It was one of those days where nothing went according to plan.  :roll:
Warpigs.
CJ
Re: Why is nothing ever simple?
« Reply #1 on: November 16, 2008, 08:32:12 PM »
thats quite a disappointment. i'm still looking forward to changing my strings for the first time on my Dean when i get back from college. i haven't a clue how to change strings on an FR.
Simon D
« Reply #2 on: November 16, 2008, 09:27:51 PM »
I don't know much about Floyds either, despite having owned 3 guitars with one! What I do know is that you should always block off the trem so it stays level when the strings come off - they're a sod to reset.
Warpigs.
Jamie
« Reply #3 on: November 16, 2008, 09:30:30 PM »
Either that or just take one string off at a time and re-string it and then start on the next string and so on.
Kevin Bond sig RR Jackson        Charvel SoCal
Ibanez Jem BSB                       Jeff Loomis Sig 7 String
Warmoth Strat                         ZW Bullseye Epi
Orange #4 TT and Cab
« Reply #4 on: November 16, 2008, 09:39:05 PM »
^  That's the way I do it!  Much easier!
Simon D
« Reply #5 on: November 16, 2008, 09:54:53 PM »
^That makes sense. I only changed the strings on a Floyd loaded guitar once, and took all the strings off because I wanted to clean the neck!
Warpigs.
« Reply #6 on: November 16, 2008, 10:40:33 PM »
you should have been ok to re-tune sooner than 24 hours,  i would wait a while on crazy shapes like banana headstocks but it aint needed for most.. depends on the glue, with a small drop of superglue it aint going to get any stronger after 1 minute.. if you use too much it takes longer so dont use too much
also, on the wilkinson the intonation is set by the screw at the back of the saddle,  that shouldnt have moved.  Just push the saddles forward till it meets the locking screw and lock them in place, you will probably find thats exactly where they were before... then check the intonation anyway!!
Simon D
« Reply #7 on: November 16, 2008, 11:06:39 PM »
There's a slight angle on the headstock, so I thought it was best to wait for a little while. Also, by that point last night, I wanted a pint! Thankfully, I didn't use too much glue, and it looks fine.
With the saddles, I just pushed them back against the screws and locked them down, and it seems to be more or less there.
Warpigs.
« Reply #8 on: November 17, 2008, 12:41:54 PM »
Just make sure not to overtighten any of the screws (usual beginner mistake - I made it in 1990 with my first FR).
Just tighten them until they show a bit of resistance, turn 1/4 turn back open (ccw), and turn then 1/2 more turn to close (cw). That way it's tight but doesn't harm anything.
« Reply #9 on: November 17, 2008, 03:36:47 PM »
Just out of interest, what sort of glue did you use on the nut?
Simon D
« Reply #10 on: November 17, 2008, 07:49:00 PM »
I used Evostick, which was what the maintanence book I've got recommended. It seems to have worked fine (crosses fingers!).
Warpigs.
« Reply #11 on: November 17, 2008, 07:52:57 PM »
That's quite a rubbery sort of glue, isn't it?  Doesn't set very hard.  I guess that makes it relatively easy to remove when you need to change the nut again at a later date.
« Reply #12 on: November 17, 2008, 07:59:12 PM »
cant say i have used evo stick in a while (never for guitar stuff), but i do remember it being a bit rubbery.
plain old wood glue or superglue work well, both used sparingly, both release with a gentle tap for future replacement
Simon D
« Reply #13 on: November 17, 2008, 08:02:41 PM »
It was Evostick wood adhesive (having just been downstairs to look at the bottle!). The book I checked (Dan Erlewine's Guitar Player Repair Guide) advised using straightforward white glue or hide glue, and my old man informed me the Evostick was white glue. I have to admit, my first reaction was to reach for the Araldite, but I'm glad I didn't.
Warpigs.
« Reply #14 on: November 17, 2008, 08:25:02 PM »
lol   definately dont epoxy the thing in place!!!
