Rackmount speaker simulators/directness
Started by Philosoful, November 25, 2008, 10:17:11 PM
Philosoful
How do these run in the signal chain? Say the flowchart would consist of Head, Cab, Rack effects + P.A, which order?/loops involved?
hamfist
If it's something like a Palmer unit, then the speaker sim would sit between your head and your cab in the signal chain. The speaker sim unit would then have a line out to feed a PA channel.
Philosoful
That be the same for the groove tubes one? I've heard real good stuff about that...
Thanks.
hamfist
Philosoful
I assume you use speaker cables for both?
+ I also assume there's no way of using my Diezel cab and some how getting that straight to the P.A without mics?
hamfist
Quote from: Philosoful on November 26, 2008, 09:21:13 AM
Yes, and correct on all points.
Philosoful
