Author Topic: "Amerty" Mullard 6v6gt  (Read 8969 times)
  • Truly bad since 1972
« on: November 28, 2008, 10:08:47 PM »
Marked as above plus L1g....are they any good, worth putting in one of my amps...any info really
hamfist
Re: "Amerty" Mullard 6v6gt
« Reply #1 on: November 29, 2008, 07:44:05 AM »
Is this an old tube, or a modern "replica ?
A true Mullard valve will have an etched code on it. Not sure what Mullard's code for  a 6V6GT is (the first 3 or 4 digits), but the last 3 or 4 digits should start with a "B" or an "R" if it is a true British-made Mullard.
Mullard made a lot of tubes (all with the codes on) which ended up being labelled for other companies.  Equally, a lot of non-Mullard tubes have been faked, and relabelled with a Mullard logo. You have to trust the etched codes here.
  In fact ALL my own Mullards are labelled either "RFT" or "Tungsram". The only tube I have that is labelled Mullard is actually an RFT !
 If the tube tests good and it's a genuine Mullard then it will be excellent.
« Reply #2 on: November 29, 2008, 10:18:34 AM »
think are original....the guy is an old amp nut..been collecting way to long....and said need a home for these 3 as he doesn't own anything 6v6....also have BVA on them and made in the USA?
Gues will have to just try them *L*
hamfist
« Reply #3 on: November 29, 2008, 04:57:04 PM »
That means nothing I'm afraid. All you need is a silk-screening machine to put whatever labels you want on a "nice" russian or chinese valve ......and there is PLENTY of that going on !
As you say, you'll just have to try them out. Have a look for etched codes when you can though.
