Author Topic: 10kpF 10MΩ  (Read 9872 times)
  • Truly bad since 1972
10kpF 10MΩ
« on: December 03, 2008, 06:19:52 PM »
These are the resistors setting....help.need a maplin available one
« Last Edit: December 03, 2008, 07:19:06 PM by sgmypod »
unheimlich
Re: 10kpF 10MΩ
« Reply #1 on: December 03, 2008, 07:08:36 PM »
Are you sure it's 10kpF ? And that's a resistor setting ???? I thought resistors are only measured in ohms...not Farads...pf is picoFarads and uf is microFarads...pf is one millionth of  a farad and pf is one trillionth of a farad,but i've never seen kpf ! And to my knowledge only capacitors are measured in Farads.
Re: 10kpF 10MΩ
« Reply #2 on: December 03, 2008, 07:18:24 PM »
It's written on schematic 10 KpF and 10Mohms on another cannot find either in maplins
http://www.maplin.co.uk/Module.aspx?ModuleNo=5729
hamfist
Re: 10kpF 10MΩ
« Reply #3 on: December 03, 2008, 08:07:56 PM »
I'm guessing that in a sort of slightly slang way a kpF could refer to a thousand (k), picofarads (pF), which would be the same as a nanofarad (nF), which is the same as 0.001 microfarads. All of these are, of course units of capacitance, and have nothing to do with resistors !!
Re: 10kpF 10MΩ
« Reply #4 on: December 03, 2008, 08:32:27 PM »
Def a resistor and is 10Mohms....KpF unsure was from a 60's schematic..but seems Maplin don't go up as high as 10Mohms
Re: 10kpF 10MΩ
« Reply #5 on: December 03, 2008, 11:17:46 PM »
10M, 0.6w metal film resistors from Rapid, item# 62-7638.  £2.20 for 100 of them.
you probably won't find a cap listed as 10,000pF, it'll be listed as 10nF or more likely 0.01uF
Re: 10kpF 10MΩ
« Reply #6 on: December 04, 2008, 09:22:39 AM »
Thanks...showing my lack of knowledge on this...just want to get it up and running enough to see what else needs replacing
sjwebb90
Re: 10kpF 10MΩ
« Reply #7 on: December 31, 2008, 11:42:24 AM »
Test
Re: 10kpF 10MΩ
« Reply #8 on: December 31, 2008, 08:01:44 PM »
*L*
