Author Topic: Pedalboards  (Read 2210 times)
Pedalboards
« on: December 06, 2008, 11:29:02 AM »
<rant>
I'm sorry - I just don't get it.
Why are pedalboards so expensive?  £150 for a bit of metal (or even plywood) and some velcro?  Come on!
If someone wants to make a killing they should make a limited run and sell them for fifty quid or so - which seems to be all they're worth.  If I was in anyway a practical sort of man, that's what I'd be doing.
</rant>
... or am I just a tight-wad?
Mark.
ailean
Re: Pedalboards
« Reply #1 on: December 06, 2008, 11:39:27 AM »
I pretty much agree.
I bought Sue a Boss pedal board, only a small one, when she first got a few pedals. It was £90 with a power supply and cables & fittings. In pedal board terms it was a good price I think as it was well designed and flexible. However, £90 for a bit of molded plastic with some foam inside and a power supply seems like a lot in anything other than pedal board terms!
If you can make your own, I'd say do it, unless you gig a lot then you might want to buy a hardcore flight case type deal to protect your gear.
Gibson LP std + Nailbomb set
Re: Pedalboards
« Reply #2 on: December 06, 2008, 11:43:31 AM »
Good quality wood isn't cheap, then there's the covering/corners/handles/labour etc - it soon adds up.  Build it cheaply and it'll fall to bits quickly.  I agree though it seems a lot of cash for something simple, but I can see where the money gets eaten up.
Do what I did, buy a used Diago Gigman for £45  ;)
Re: Pedalboards
« Reply #3 on: December 06, 2008, 12:05:19 PM »
My TKL pedalboard was about £30 and its been fine for a couple of years (I think) of gigging and regular use, the psu I use is quite cheap and its started to become noisy, though. Bit too large for me though, I wish I got the medium or small version.
