Author Topic: Phase reversal button - Jimmy Page style(ish)  (Read 5460 times)
« on: December 07, 2008, 06:27:12 PM »
I have my old Gibson which has two mini switches.
One splits each coil, however I want to revert the original switch back to master coil tap, and add a push button in the spare slot to put the two pickups out of phase with each other.
After looking into it, I think I want a: DPDT push push on/on latching mini button - any advice as to where I could find one of these, if not, what are my options?
I assume I could do this with 3 conductor wire? (hot - coil short wire - ground)
Thanks
Re: Phase reversal button - Jimmy Page style(ish)
« Reply #2 on: December 16, 2008, 04:35:26 PM »
Ok, so... people don't want to answer that type of question.
IF it were to be a push pull, that would be DPDT? Other than that, I think I am sure, would just like some comfirmation here.
Thanks... In advance ;)
ToneMonkey
« Reply #3 on: December 16, 2008, 04:38:15 PM »
Wish I could help mate, but electronics ain't my thing.  I would try over at the Project guitar forum as they have some good electronics people over there that could probably help.
« Reply #4 on: December 16, 2008, 04:46:36 PM »
this is the closest i can find:
http://www.guitarelectronics.com/product/WDUHH3T2207
on that the switches are attached to the pots  as push/pull pots but that doesnt really matter as long as you use two DPDT switches
« Reply #5 on: December 16, 2008, 09:53:06 PM »
Thanks, looks do-able with my 3core wire, and the type of switch looks similar.
I think it would be cooler with dual buttons, just hit it and it changes.
Those ones look like they would fit under the pickguard JP style, and I am sure it will be easy to find some normal button types
