Author Topic: Dark pickups for bright guitar  (Read 4114 times)
MesaExplorer
« on: December 17, 2008, 04:36:12 PM »
Hi guys, I think I'm finally getting around to ordering a set up BKPs; however, I'm slightly concerned about the woods my guitar is made of for getting a more optimal tone.
I have a Carvin DC-747 (HSH) 7 string made of walnut with a maple/walnut neck.  It's pretty bright as you could imagine.  Looking to replace the bridge and neck humbuckers.  I'm wondering which pickups offer a high output, dark lows, and a pretty nasally and raunchy midrange for the bridge.  For the neck I'm thinking something with a lower/mild output, more harmonics (for it's relative position), with huge amounts of mids and a moderate low end .  Getting treble isn't really a problem for either position.
Any help will be greatly appreciated.
« Last Edit: December 17, 2008, 04:38:23 PM by MesaExplorer »
Antag
Re: Dark pickups for bright guitar
« Reply #1 on: December 17, 2008, 04:45:21 PM »
Holy Diver calibrated set - your description fits it almost perfectly.
MesaExplorer
« Reply #2 on: December 17, 2008, 04:53:49 PM »
Thanks man!  I appreciate it.
Antag
« Reply #3 on: December 17, 2008, 04:54:47 PM »
Oh hang on a second - I didn't notice "7 string" bit in your post  :oops:
I still think an HD set would work well, but it depends how much tightness you want for the low B (assuming that's how you have it tuned) - are we talking Nile-esque DM riffage or a looser more organic kinda style like early Korn?
Painkiller bridge would give you the ceramic tightness but still with massive mids & plenty of low end.
VHII neck would go well with it, it has a nice PAF kinda neck tone but balances with the high output bridge models...
Antag
« Reply #4 on: December 17, 2008, 05:04:55 PM »
Just to clarify, I'm not saying Holy Diver can't do low tunings, just that I've never tried it.  The lowest I've ever tuned it is drop-C# for this clip (the second attempt that I posted at the end of the thread is better than the one in the first post)
I thought it sounded OK, so I imagine tuning 2 steps lower than that wouldn't be disastrous...
MesaExplorer
« Reply #5 on: December 17, 2008, 05:46:04 PM »
I'm playing in standard, fairly light strings, and again the wood used is extremely bright.
About the heaviest my playing gets with the Carvin is shred, Dream Theater, Metallica, Megadeth.
MesaExplorer
« Reply #6 on: December 17, 2008, 05:54:15 PM »
Is there a warpig 7?
Do they offer gold tops for the holy diver in 7 as well?
I'm thinking HD in the neck and a Warpig in the bridge.  Sounds like a win judging by the description.
« Reply #7 on: December 17, 2008, 06:05:14 PM »
the darkest high output BKP's are the miracle man and warpig neck versions
they both have a huge output and a nice voicing for bright guitars
and they are surprisingly good for the bridge position
the MM neck is just like a holy diver bridge, but a bit fatter and more nasal
like a dimarzio tonezone type of voicing
MesaExplorer
« Reply #8 on: December 17, 2008, 06:09:46 PM »
Did you mean the Miracle Man and Warpig as bridge versions?
So Miracle Man neck, Warpig bridge...should be pretty damn beefy right?
« Reply #9 on: December 17, 2008, 10:17:59 PM »
the neck versions, but used in the bridge position
MesaExplorer
« Reply #10 on: December 18, 2008, 06:57:10 AM »
I see. Cut back on the output a bit with the slightly tamer calibration.  Thanks for the help man!
« Reply #11 on: December 18, 2008, 02:02:59 PM »
actually the neck versions are completely different from the bridge versions
but they are as powerful as a bridge pickup, so they work great installed in the bridge position too
as they have a more nasal high end, they might be good to tame the brightness
but a Holy Diver would be great anyway
but if you wanna go any darker, than try a MM neck in the bridge position
