Author Topic: Loose Nut  (Read 3926 times)
mikeluke
Loose Nut
« on: December 23, 2008, 08:19:21 AM »
Simple question - I've just been cleaning and restringing a guitar for a friend and the nut is loose - as in no longer attached to the guitar - what should I use to stick it back on? I am guessing that I want something that is fairly solid but could eventually be removed if required - any advice appreciated - many thanks
Mike
Mules, Riff-Raff
Re: Loose Nut
« Reply #1 on: December 23, 2008, 08:32:56 AM »
Super glue (at most 2 drops) or the glue woodworkes use to glue woods, can't remember the name now... worked all night and need sleep  :orczz:
mikeluke
Re: Loose Nut
« Reply #2 on: December 23, 2008, 09:15:50 AM »
Boa noite.. obrigado
Mules, Riff-Raff
Re: Loose Nut
« Reply #3 on: December 23, 2008, 09:23:44 AM »
yeah, a little superglue or plain old wood glue like titebond..
what you want is something that holds it in place but releases easily
just a little hint - dont take bottles/tubes of superglue over the guitar.. put a little drop on the nut rather than try to put a little drop in the nut slot
Re: Loose Nut
« Reply #4 on: December 23, 2008, 02:12:55 PM »
Unfortunatelly it's day :( hehehehe
Follow Wez's tip, if the guy ever need to change the nut (not very unnusual), with much glue he will be like having trouble and with a big chance of messing the work, like breaking some part of the wood, etc...
