Author Topic: Splitting Hums  (Read 1454 times)
Spitfire
Splitting Hums
« on: December 24, 2008, 12:51:24 PM »
Hey, im just thinking about a possibility here..
i want a strat with HSS setup...I want a pretty high output Humbucker, and some lowish.. in the gilmourish feel singles.. (im thinking apache's or something.)
which out of all the BK humbuckers would split to a single that would have a close output to a gilmourish feel?  i know that a SSS setup would be best.. or maybe a lower output hum like a VH2.. but im not looking for that really.
im just thinking at the moment, no definite plans
Fender Telecaster
Jackson KV-4
Starfield SVA-1
Transcend
Re: Splitting Hums
« Reply #1 on: December 24, 2008, 03:16:00 PM »
I still say you should get a MM the singles can cover the gilmour and for when you wanna do anything metal you can flip tothe MM
also it is great for leads.
Antag
Re: Splitting Hums
« Reply #2 on: December 24, 2008, 04:01:55 PM »
I'm going to disagree here because I had the Miracle Man paired with low output singles (Sultans) in an HSS strat.  It was my first BKP purchase & never really worked.
Basically, there was such a huge difference in power between bridge & mid/neck that if you dialled in a nice clean sound for the singles, the bridge position was unusable.  Dial in a nice gain sound for the bridge & the neck just sounded weedy.  Also, the MM bridge doesn't have a particularly nice clean sound (even split).
FWIW I swapped the MM for a Nailbomb (kept the Sultans) & it's much, MUCH better.   The NB is still more powerful, just not skull-splittingly so :)  Also, it's more organic with a far nicer clean sound & splits well.
So that would be my vote based on experience: Nailbomb + Sultans/Milks/Apaches
(NB: I've never tried Mothers Milks or Apaches, so am assuming that they are similar power level to Sultans...)
Fikealox
Re: Splitting Hums
« Reply #3 on: December 24, 2008, 07:43:37 PM »
Yeah, I'm not sure a really high output humbucker and low output singles will really play well together. It might sound like a good idea to increase versatility, but it'll just make your life harder.
The BKP site itself has some good HSS suggestions, like NB/IT/IT, MM/TS/TS, HD/IT/IT etc. It really depends what flavour humbucker you're looking for.
BKPs (soon): CS, TS.
