Author Topic: Best thing to take one guitar input and make 4 outputs  (Read 4854 times)
« on: January 06, 2009, 11:37:42 AM »
Like it says
Chain signal splitters?
Headphone amp?
What?
The outputs have to go into modellers, amps, preamps, interface high-z, that sort of thing. Normal guitar level high-z.
Any suggestions?
Transcend
Re: Best thing to take one guitar input and make 4 outputs
« Reply #1 on: January 06, 2009, 11:44:19 AM »
Hmm im not entirely sure on this but i think that Ben will be able to give you a good answer
Oli
« Reply #2 on: January 06, 2009, 01:06:13 PM »
Well, Lehle do a unit that will take a single guitar, and split it 3 ways. If you don't need simultaneous outputs (ie, you want to use the modeller or the preamp), then you can build a very simple device into a stompbox-size unit, using just a rotary switch, some wire and the connectors. If you are wanting multiple outs at the same time, then you'll need to buffer the signal to avoid loading the pickups down.
« Reply #3 on: January 06, 2009, 01:33:50 PM »
Radial also make some splitters - depends how much you want to spend on it.
« Reply #4 on: January 06, 2009, 02:03:06 PM »
I was looking at radial. Theres an X-amp on the way, and they seem to have their game down, but I'd need 3 or 4 of them and the cost goes up really fast.
A single unit would really be best. I'll look at lehle, thanks oli.
« Reply #5 on: January 06, 2009, 02:05:41 PM »
The Lehle SGoS looks really good.
Antag
« Reply #6 on: January 06, 2009, 02:15:07 PM »
If you need the outputs all at once then the Morley George Lynch Tripler will give you 3.
If not, then the Lehle 1@3 will allow you to choose between 3.  I have the 3@1 (i.e. switch between 3 inputs - for easy guitar changes) & it's awesome.
However, I don't know anyone that makes a 4 output switcher...
« Reply #7 on: January 06, 2009, 02:18:53 PM »
Yeah, a closer look at the lehle and its switching. Which is great, but I need all on at once.
I'll check out the trippler. That and one splitter would get the job done pretty well, I suppose.
« Reply #8 on: January 06, 2009, 02:20:31 PM »
Any idea where to get it? Google doesnt come up with UK shopping hits
Antag
« Reply #9 on: January 06, 2009, 02:36:46 PM »
Thomann have it  - & that's still a good price even with the £ having tanked vs the € :)
Antag
« Reply #10 on: January 06, 2009, 02:42:50 PM »
« Reply #11 on: January 06, 2009, 03:10:45 PM »
Cheers.
I found it at strings direct, but they dont have it in at the moment. They're calling me back (cos I also need strings anyway!)
« Reply #12 on: January 06, 2009, 05:33:02 PM »
DV247 have a facility to make stuff like this, so seeing as the 4-splitter doesnt appear to exist, they're making me one :D (for £20! Too cheap not to try it!)
« Reply #13 on: January 06, 2009, 05:58:50 PM »
Don't read reviews on the Lynch thing ;) apparenetly its shitee.
voodoo labs seem to do something along those lines I think
