discriminate neck from bridge The Mule
Started by Iced Dragon, January 09, 2009, 04:21:19 PM
Iced Dragon
Hi,
a little question here. I bought a TM secondhanded, assuming it was a bridge version (as was mentioned in the description).
Now, taking a closer look at the back, there's an 'N' engraved and has a red round sticker. Is this/are these an indication for a neck-pup instead?
Thanks
Cold Sweat b&n (RR1, Dinky)
HD + Trilogy (Hamer Centaura)
Sultans, Mother's Milk n (strat)
Flat '50s (CV50 Tele)
Abraxas, Sultans (EBMM Silhouette)
Stormy Monday, Crawler, Mule, '63s, Blue Note
Correct, the red sticker indicates the neck pickup.
Iced Dragon
oh cr@p  :(
Are there more differences then lower volume in neck pups?
There are many variables in the Mules.  It could have Alnico II or IV magnets and it will have a lower DC resistance than the bridge.  Did you get the cardboard insert/description that comes with the pickup, as that will tell you the magnet type and DC?
Iced Dragon
No, unfortunately not. If I'm not mistaken, it came in a SD case ... :mrgreen:
Evilbay  :?
So, only through applying a multimeter I could get some info, I guess?
ailean
Yeah a multimeter will tell you which it is, but it's sounding like the neck.
DC: Bridge 8.4K, Neck 7.3K
On the plus side it's going to be a bloody good neck pickup so put in the neck and enjoy!
Gibson LP std + Nailbomb set
Fikealox
Also measure the distance between the centres of the outside polepieces. If it's 53mm, you've got a bridge version. Odds are it'll be 50mm (since Mules are most popular in LPs), which won't tell you anything, but it's worth trying.
BKPs (soon): CS, TS.
Iced Dragon
It's 50mm for sure ...
Unfortunately, I don't have a guitar with a neck-humbucker to use it at the moment. But I'll keep it aside allright!
You can still use it as a bridge pickup.  Remember when Gibson first made humbuckers they didn't calibrate them, they just fit pickups from the same bin in both positions and it was luck of the draw as to how they balanced.  If you are using single coil pickups in the other positions it will work fine (and may balance really well).  I used to have an old PAF in the bridge of one of my strats, with the old Fender pickups in the other 2 positions and it was a great sounding guitar.
Iced Dragon
Yes, it didn't really sound bad, and indeed I use it with SCs. I actually loved it split with the middle SC  :P
