Author Topic: Pickup routing?  (Read 2964 times)
Gizmo
Pickup routing?
« on: January 12, 2009, 12:38:28 PM »
How easy is it to route a guitar for a humbucker or how expensive is it to get someone competent to do it for you?
Been looking at Tele's for a while but some of the ones I like dont have the routing in the neck position.
Lew
Re: Pickup routing?
« Reply #1 on: January 12, 2009, 12:42:03 PM »
Easy for someone who knows what they're doing, I have used this chap Steve before for routing http://www.manchesterguitartech.co.uk/
Antag
Re: Pickup routing?
« Reply #2 on: January 12, 2009, 12:53:18 PM »
Just expanding the neck pickup rout from single to humbucker is a fairly straightforward job - the wiring hole is already drilled & you've got the smaller rout to use as a starting point.  As it's under a pickguard, there's no finishing work to be done.
Feline is a genius with a router - he routed a Floyd Recess for me (i.e. a much more detailed job) & IIRC it only took him an hour or two of labour...
Gizmo
Re: Pickup routing?
« Reply #3 on: January 12, 2009, 01:08:04 PM »
ok thanks for the advice. I may ask him once i know what guitar I want.
Also, where would be a good place to source a black bakelite pick guard with a humbucker space?
I'm basically after a vintage looking tele. I love my american deluxe strat but the tele equiv is too modern looking.
Ive seen pic's of those Road worns and they look really good (to me anyway). You might think im mad but the blonde with a black guard, either a SM or Mule in neck and some hot vintage PUP in bridge @£900 all in.
ToneMonkey
Re: Pickup routing?
« Reply #4 on: January 12, 2009, 01:13:54 PM »
Not seen one for a while, but I'm axesrus had some a while ago.  Chances are that whoever does your routing will be able to get one/make one easy enough (especially if you give them your old one as a template.  Depending on what you buy an off the shelf one might not fit anyway.
