Celestion solder only tag panels?
Started by TomW, January 14, 2009, 04:33:24 PM
TomW
I've just bought 2 celestion heritage g12h30 speakers, and all previous speakers I have installed have just had the normal tags that you can slot on. But these have solder only tag panels. How exactly do you wire them up? Is it just a case of slotting the wires onto the tags of the speaker and then soldering that, or do I need to use a different type of wire without tags on the end?
Cheers for any help
Riff Raff/Stormy Monday, Holydiver and Mississippi Queen!!!
www.myspace.com/therealamorist
hamfist
Quote from: TomW on January 14, 2009, 04:33:24 PM
Cheers for any help
Same wire. Just remove the tags, strip off a little bit of insulation and solder to the appropriate tag on the speaker !
Its just a connection for electricity. You can connect two things in many different ways. Personally I prefer soldering to push-fit connectors on speakers.
TomW
Ahh ok, Cheers for the fast reply. I'll get installing them now then  :D
bobthemerciful
I never trust spade (push-on) terminals on speakers. I always solder em. A tranny amp may be able to cope with the impedance change if one of em comes off mid-gig, but not many valve amps would like it at all.
[url="//www.bobelliott.co.uk"]www.bobelliott.co.uk[/url]
Catalyst77
I had the same problem a few months ago, i just cut then ends of as recommended and soldered them on directly.  In fact i also bought the same speakers!
Wasnt from some guy on ebay was it?
TomW
Nah I got mine from lean-business. I decided to solder them all in the end aswell cos when I opened it up some of the tags we're close to falling off by themselves. Thanks for the help guys.
while you're at it, replace the speaker wire with something beefier - you will notice an improvement in the tone (not massive, but certainly noticeable imo).  I just use the Van Damme speaker cable from Maplins, it's nice stuff and only around £1.50/metre
