Author Topic: Help REgarding Muffled Tone.  (Read 3868 times)
Lukemc
« on: January 15, 2009, 10:21:20 PM »
Hi ive just tried to instal a pickup that i bought from BKP(bkp-92) and i think i may have damaged the VOlume pot or i have connected something wrongly.
the NEck pickup is fine as i did not replace this but the new Bridge pickup is Half the volume it used to be and sounds Dull, lifeless and muffled.
i even tried the old stock pickup back in and it sounds teh same, dull, lifeless and muffled.
have i fried the Volume Potentiometer with teh Soldering iron? or anything you know of?
Thanks, PS Quick advice would be appreciated.
Luke.
Re: Help REgarding Muffled Tone.
« Reply #1 on: January 16, 2009, 08:25:31 AM »
Sounds like you bust the pot if the old pickup has the same issue...
Fourth Feline
« Reply #2 on: January 17, 2009, 07:14:20 PM »
- " If in doubt, whip it out " ....  :)
« Reply #3 on: January 18, 2009, 05:59:29 AM »
you can make a quick check by connecting the pickup wire direct to the output socket, and then reduce from ther. the PU has no tap? Just two wires, right?
