Author Topic: Replacing old "hunts".can cap  (Read 2510 times)
  • Truly bad since 1972
« on: January 21, 2009, 08:03:14 PM »
has 3 poles red, yellow and blue....how does this match up to new cap which has + + -...please help
Re: Replacing old "hunts".can cap
« Reply #1 on: January 21, 2009, 08:31:16 PM »
sounds like a dual section cap - you'll have two capacitors in there with a shared ground (-'ve connection).
have a look and see which one of the three connections goes to ground - the other two are your +'ve connections.
« Reply #2 on: January 21, 2009, 08:41:47 PM »
think can is ground
« Reply #3 on: January 21, 2009, 08:43:51 PM »
says red32uf, yellow 32uf, green 32uf, can negative
« Reply #4 on: January 24, 2009, 01:37:20 AM »
ahh, it's one of the ancient types.  ok, strap yourself in... typically on a multi-section cap you have a shared ground tab plus two or more +'ve connections.
in the type you describe, the actual body of the can is your ground connection - is it a twist-lock type with the body fixed to the chassis directly?  anyway, the other three sections (red, yellow, green) are all +'ve connections.
those three-section caps are much harder to find these days - I had to replace one in a Selmer T&B one time and ended up with a dual-section can cap and a single axial cap wired to some tagstrip.
it's a bit better now though as I'm sure JJ and maybe even F&T make a three-section can cap.
(ok, back now), AES stock the JJ four-section cap, but it's a 40uF, 20uF, 20uF, 20uF cap... http://www.tubesandmore.com/scripts/foxweb.dll/moreinfo@d:/dfs/elevclients/cemirror/ELEVATOR.FXP?item=C-EC40-20X3-500  Wire it up with two of the sections in parallel so you get 40/40/20.  the slightly lower filtering on the 20uF stage will make a negligable difference, but if it bothers you just add a 20uF axial cap across that section of the can cap and have 40/40/40 - perfect!
actually, looking again, they stock a 30/30/30uF can cap which is perfect, or you could get the 40/40/40uF one if you want slightly more filtering... CAPACITOR, ELECTROLYTIC, 30/30/30 µF @ 525 VDC...  part# C-EC30X3-525 (30uF x3 @ 525v)
« Reply #5 on: January 24, 2009, 09:50:11 AM »
cool not bad price if can't sort the other way may have to get one
