Now I have an Egnatger Rebel - for free!!!
Started by hunter, January 22, 2009, 12:08:06 PM
well, cheat cheat, just a virtual one ...
Cliff/Axe-God added it to the Axe FX in his latest FW update :O)
Here the release notes:
6.08
The Enhancer, Filter and Volume blocks now have Pan Left and Pan Right controls.  The controls allow panning the left or right output signal in the stereo field.  Theses blocks can now be used as generic stereo manipulation blocks. You can use these controls to adjust the stereo image, pan both signals to one side or turn a stereo output into two mono outputs.
To eliminate confusion many controls previously labeled "PAN" are now labeled "BAL" (balance) as this is more representative of the control's function.  Balance adjusts the relative level of the left and right signals.  Pan, on the other hand, adjusts the position of a single signal in the stereo field.
Added features to Enhancer block.  You can now invert either or both channels and control the panning of each channel.
Changed Master Pitch range to –100 to +100 percent.  Any presets using Master Pitch other than 100% will need to be auditioned/edited.
Added Input Volume control.  You can now adjust the input volume (using a pedal input or MIDI CC).  Some people prefer adjusting the volume at the input as this mimics a volume pedal before an amp and allows effect tails to ring out.  Be sure to check the setting of this on the I/O->CTRL page.  Set to NONE to defeat.
Added modifier capability to Amp block Drive control.  NOTE: This places a heavy burden on the CPU.  If you attach a modifier to the Drive control your CPU usage may increase several percent.  The Boost function has been moved to below the Type knob.
Added modifier capability to Amp block Master control.
Exposed amp modeling power supply filter capacitance.  This parameter, under the advanced page and labeled "B+ CAPACITANCE", allows you to adjust the B+ capacitance of the amp model.  Defaults to preset value on type change.  Increasing value stiffens response and tightens bass.  Decreasing value loosens response.  Use in conjunction with Sag control to set response.
Added Bright Cap parameter to Amp block.  You can now adjust the value of the "Bright Cap" across the virtual Drive pot.  Defaults to a preset value on type change.  Naturally, the Bright Switch (under the Treble control) must be on to hear the effect.
Added Deep parameter to Amp block.  This replaces the previous Deep switch and allows the actual amount to be varied.  This is analagous to the Deep control on some modern guitar amps.  The Deep control is on Page2 of the Amp menu.  Its value defaults to a default value upon type change.  The old Depth control has been moved to the Advanced page and relabeled TRNSFRMR MATCH (Transformer Matching) as this is more descriptive of its function.
Tweaked "Jr. Blues" model.  Adjusted speaker resonant frequency and preamp-to-poweramp coupling capacitor.  Fixed wrong value for bass pot.  Changed mid pot taper to agree with newer "cream" models.
Added "Eggie R20" model.
Added Low Cut, Hi Cut, Clip Type and Bias parameters to Drive block.  These parameters default to values when the Drive type is selected but may be overridden.
Tweaked the default high cut frequency on some of the Reverb types.
Improved pitch detection algorithm.  False locks have been eliminated.  Tracks better on complex chords.  Tuner can detect lower notes.
Removed Delay Ducker on/off switch as this was redundant.  To defeat ducker simply set Ducker Attenuation to 0 dB.
Added Filter Slope selection to Delay block.  Filter slope can be selected as 6, 12 or 18 dB/octave.
Tap Tempo now intelligently detects momentary or latching tap.
Fixed a couple knobs responding to Enter that shouldn't.
Tweaked MIDI code some to improve editor interaction.  Will require new editor version for best benefit.
You nearly had me uber-jealous!
I cant believe how great My Egnater is and how cool it is to have it in the workshop as an amp for testing guitars
Quote from: FELINEGUITARS on January 25, 2009, 07:22:24 PM
... I thought you had been quiet on the forum for a bit, Jonathan...  Has it been noisy in Croydon?
Mark.
