Which BKP's for PRS SE Custom 22
Started by ByronBlack, January 23, 2009, 12:15:45 AM
ByronBlack
Hey chaps,
I've spent ages listening to the various sound-samples, and have confused myself so much I have no idea what I'm doing anymore.
I'm going to purchasing a PRS SE Custom soon (mahogany and maple body & mahogany neck) and want to ditch the cr@ppy HB's that come with it.
Now, the type of music I will be playing is Metal, Blues and some clean stuff. I need a super 'chugga chugga' palm muted rytyhm (metallica style sound) from the bridge, and a nice warm Slash style solo from the neck that will also clean up nicely for more bluesy overdrive.
At the moment, I'm leaning towards a MM in the bridge and a Cold Sweat in the neck, but it's difficult to really know what I'm thinking as I've listened to so many samples.
My Rig is a Blackheart Little Giant Head and Matching Cab, being powered by an ADA MP-1 Preamp.
Any thoughts would be greatly received.
Frank666
cold sweats will cover that very well
Before I even saw the answers above, I thought Cold Sweats.  I have a set in a PRS McCarty Korina.  They'll do all that you need!
ByronBlack
Hey guy's, seems like a unamious decision. Are you all suggesting that I go for a cold sweat in the bridge as well? Is it a high output 'bucker with a tight bottom end like an MM?
Zaned
Hi,
I have a calibrated Cold sweat set in my PRS McCarty. Compared to your guitar, there's more mahogany, but I suspect that the pups would work nicely anyway. NOTE: the neck is Alnico V, the bridge is ceramic. They balance very nicely, both in tone and in volume.
I don't own a Miracle Man, but Cold sweat is not like it. It has a tight and fast-tracking bottom (like Jessica Biel), a midrange that is not spiky , and a detailed, cutting high end (but not harsh!). My guitar puts out quite a bit of midrange, being warm but clear. That's why I went with the cold sweat, as it had that tight attack and a very defined sound with a balanced midrange. Despite being ceramic, it sounds organic :)
The neck pup is a bit different. It has a tight attack too, it really sings and has a very detailed voice. It ain't exactly Slash's neck tone, he's got a looser bass and overall darker tone there. BUT, at least on my PRS, the tone control works very nicely. If I turn that down, the highs become less apparent and more midrange shines through. It goes very clearly (pun not intended :D) towards the Slash territory then.
-Zaned
Paths are for followers.
elijen
Quote from: Zaned on January 23, 2009, 09:55:11 AM
interesting...should the pups be named in a different fashion in the future? 8)
+1 on CS set (don't own it, eventually will get it, sounds like the right choice for you and me both :))
#7
Quote from: ByronBlack on January 23, 2009, 09:33:25 AM
I swapped the miracle man in my les paul copy for a cold sweat
besides some punch loss (the miracle man is like a sledge hammer), everything got better
it's similar to both miracle man and painkiller (I had the painkiller and miracle man in another lp copy), but less extreme than both
it's a very hot pickup, but very balanced
not too bassy and trebly like the miracle man (yeah, the MM is extremely bassy AND trebly  :lol:) and not extremely middy like the painkiller
it's as tight as the miracle man, a hair less than the painkiller and warmer on the top than both
it's a bit brighter than both, though
it has a beautiful crunch in the midrange, similar to the miracle man grind, but the whole miracle man midrange is focused on the low mid frequencies, while the cold sweat is very even voiced
I wouldn't say it is a fat sounding pickup, but will sound fat in fat sounding guitars (lol)
it's a perfect match for mahogany, since it doesn't boost the bass and mids, neither scoop them out, but adds a nice bright top without any kind of harshness or getting spikey in the higher strings
the miracle man is not harsh at all, but it reacts weird for each string... gets very dark on bottom strings and very bright in the higher strings (the bill lawrence l500xl has this characteristic too, but the miracle man has like 5x more low end, so it's more noticeable)
comparing to famous pickups, I'd say it's voiced between duncan custom sh-5 and duncan distortion sh-6, with bill lawrence kind of clarity without the mid scoop and sterile thin treble, and it has that huge gibson 500t grainy crunch without the mushy bass and muddy mids, definitely hotter than dimarzio super distortion, but brighter and not as middy
it definitely sounds very ceramic, but it is the most organic, warmest and clearest sounding ceramic pickup I've heard
AdamB
#8
Quote from: Eric Hellstyle on January 24, 2009, 02:35:50 AM
Eric, that was a great description! I think you've talked me away from Nailbombs in my new guitar, haha! Saying that, Nolly did half the work ;)
Or maybe a ceramic nailbomb....hmmmm...
Anyway, not my thread, sorry!
SG-X/Over wound Rebel Yell
Blue SG 61 Reissue/Cold Sweat
Egnater Mod 50
Matamp 4x12
