Quote from: Sid on April 13, 2012, 01:10:51 PM
Yeah it has a large scratch plate (modern standard) so I guess I'm screwed. :/
No, you'll be alright - if you look at the guitar now, quite a lot of the bridge pickup sits above the scratchplate but you can't see the
whole of the pickup cover so the legs are still sitting below the plate.
You almost certainly won't be able to use the long springs BKP supply, but just get some shorter springs or some of the rubber tubing Fender use. It'll be fine. :)
