Leg length on pickups
Started by riverbluff, January 27, 2009, 12:19:57 AM
riverbluff
Which leg lenght do I need to get?  I can't remeber and I don't want to dis-assemble anything to find out.
It is going into a carved top VW body.
Looking at either a Riff Raff set or Holydiver set.  I was something that is nice for heavy to classic rock.  Any other suggestions?  I was think Nailbombs for a while as well.
V/R
Bill
Looking at that body, you may be able to use long legs.  However, the safest bet is to get short legs as they'll fit 99% of guitars.
One exception is the Gibson SG Standard, where you need long legs to raise the pickup high enough out of the scratchplate.
Tellboy
Quote from: Twinfan on January 27, 2009, 09:23:58 AM
Unless you have Mk1 type SG (or 61/62 Reissue) with small pickguard and separate pickup rings (a la Les Paul) in which case short legs are OK. I have found that long legs on the neck pickup of my 61 reissue makes  the neck pickup 'bottom out' so I can't lower it as much as I would like.
That's why I said SG Standard, and not SG '61 reissue  ;)
Tellboy
#4
Quote from: Twinfan on January 27, 2009, 05:00:44 PM
I have a an original 1964 Mk 1 SG Standard with the same problem  :wink: After all the '61 reissue is a (not particularly exact) reissue of the small pickguard Standard  :wink: As I said it seems to apply to small pickguard SG Standards with seperate pickup rings not batwing pickguards.
Ha ha!  OK, modern Standards  ;)
It's all to do with the neck angle of the newer guitars  :)
Quote from: Twinfan on January 27, 2009, 05:37:38 PM
The same applies to Flying Vs.
Let's say Gibsons with scratchplate-mounted pickups!  :wink:
mikeluke
Phil/Dave
So - which leg length would I need for the bridge pickup for this SG...
Fingers crossed that I have bought the right one!
Mike
Mules, Riff-Raff
Quote from: mikeluke on March 25, 2009, 05:20:24 PM
Phil/Dave
You could go for either, Mike.  Personally I'd go short, just for the extra bit of spring tension so the pickup doesn't wobble.
mikeluke
Phil - thanks - so you can guess which one I have, can't you? :lol:
A nice long leg Riff Raff! I guess that I could always get Tim to shorten it....
Mules, Riff-Raff
Looking at the picture Mike, I think you might get away with a long leg in that one?
mikeluke
I bloody hope so! I've got a Riff Raff (long legs) to go in the bridge and I will then swap the current bridge into the neck position until I find a suitable BKP replacement - have to say that I didn't think about the legs when I bought it - doh! I've got the new pickguard, knobs and pickups mounting rings (black) all ready to go. Just need to collect the guitar now.
Mules, Riff-Raff
The long leg will be fine because you've got a tall pickup ring.   You can always use extra long springs for a bit of extra tension (the BKP ones tend to be long anyway!).
Sid
That's a little confusing the guy on the phone at bareknuckle pickups told me to get short leg pickups for my sg in fact so did my guitar tutor... :/ I hope mine fit.
Quote from: Sid on April 13, 2012, 11:41:24 AM
If your SG has pickup rings, you can go with long or short (personally I prefer short).  If it has the pickups mounted on a big scratchplate (modern SG Standard or Special) you're better off with long legs - at least for the bridge pickup.
