Author Topic: best wah pedal for modern metal (at around £50-70) ?  (Read 8254 times)
the prince of shred
« on: January 28, 2009, 12:12:25 PM »
i want to get a decent war pedal to work at hi gain levels for metal solo's like triviums machine heads etc... but i would also like to be able to achieve a vintage hedrix wah sound .... what wah can do this? (metal tone more important but hendrix also a factor to consider) im looking at around £50-70 price range ...
thanks
Lew
Re: best wah pedal for modern metal (at around £50-70) ?
« Reply #1 on: January 28, 2009, 12:17:40 PM »
It's a big tone pot.
Different wahs have different sweeps/qualities, but I've never heard of a 'metal' specific wah... unless ofc you buy into marketing hyperbole aimed at 14yr olds... in which case get a Morley Tremonti wah  :lol:
You can still get italian 70's Jen crybabys with fasels for cheap on ebay, the more beaten and dirtier it is the more vintage it sounds ;-P
 8)
« Last Edit: January 28, 2009, 12:23:21 PM by Lew »
the prince of shred
« Reply #2 on: January 28, 2009, 12:25:05 PM »
i realise this is a wide range, and i dont know anything about wah pedals really thats why im asking for help, i just wonderd what wah was good for hi gain work and im guessing i want a large sweep?
Lew
« Reply #3 on: January 28, 2009, 12:32:43 PM »
It all depends on what your ear likes, there are no rules. Some players like the high end on a Dunlop and some like the wider and rounder Vox and the rich players like the Clyde wah  :lol:
Go try some out :-)
Spitfire
« Reply #4 on: January 28, 2009, 12:49:53 PM »
gcb-95 for about £50 and do the simple true bypass mod..
Fender Telecaster
Jackson KV-4
Starfield SVA-1
d1dsj
« Reply #5 on: January 28, 2009, 12:56:03 PM »
If I were you I'd save a bit more cash and get a Teese Wizard Wah, they were made specifically for humbuckers. I use mine in a covers band, I don't use it alot... but for tracks like Sandman, Sweetchild type stuff it's ideal. Check out Teese's website before you buy.
nfe
« Reply #6 on: January 28, 2009, 05:14:54 PM »
+1.
« Reply #7 on: January 28, 2009, 05:55:41 PM »
+ some of the circuit mods from the diy section of this website here
http://www.wah-wah.co.uk/
as standard i would do the vocal and sweep mods to make it a really usuable wah, i find the vox and crybaby wahs to be very quacky and those mods really help with that
dheim
  • DON'TPANIC!
« Reply #8 on: January 28, 2009, 07:52:14 PM »
...the not so modern crybaby?
i've got the jimi hendrix edition and it screams!
too many? ;)
sjwebb90
« Reply #9 on: January 28, 2009, 08:50:41 PM »
I have a Budda wah which is great in its own right and it has true bypass. I have also added an LED to show when its on and off via the 3PDT bypass switch  I have added a switch under the treadle to change resistor values to go between the normal wah and more vocal wah. I  used a 47K ohm resistor for the vocal type wah.
I also have a Dunlop GCB95 which I have tinker with. I have replaced the on/off switch for a 3PDT plus an indicator LED, plus I did the vocal switch mod. I also replaced the Inductor with a Fulltone. The key to a good sounding wah is the build and accuracy of the inductors. (500mH).  Most are way off the mark. I also added a three way rotary switch to switch between different values of capacitors to change the sweep range.
There is lots on the web regarding wah modification.
http://www.diyguitarist.com/DIYStompboxes/WahMod.htm
http://www.geofex.com/article_folders/wahpedl/wahped.htm
http://www.home-wrecker.com/wahmods.html
Simon D
« Reply #10 on: January 28, 2009, 09:03:25 PM »
If you want a wide sweep, the Dunlop Zakk Wylde wah is worth looking at. It's a little over the budget, but you can sometimes pick them up in a sale (as I did with mine for about £70) or on Ebay.
Warpigs.
Ted 'N' Leo
« Reply #11 on: January 28, 2009, 09:24:51 PM »
I've got the new Jimi Hendrix Dunlop, with the chrome top, and its very nice. Got it for around 80 or so from guitar guitar.
I've also heard the fulltone one is pretty good, maybe have a look at those in the second hand market. I think they're quite expensive.
ChunkyMunky
« Reply #12 on: January 29, 2009, 12:40:11 AM »
SH Bad Horsie?
DimeZakk
« Reply #13 on: January 29, 2009, 12:45:05 AM »
Dunlop Zakk Wylde Crybaby wah
« Reply #14 on: January 29, 2009, 08:09:25 PM »
The bad horsie is the best wah pedal I've ever used when it comes to playing with gain.
I'd definitely grab one.
