What can I use as DIY nut shims?
Started by Pierre, January 31, 2009, 04:58:25 PM
Pierre
I was thinking putting several layers of paper on the nut shelf, followed by a light, light soak up in super glue, then put the old nut on top..?
Normally a thin slice of maple would do the trick but I have absolutely no way of using this...
No clue what else really... a bit of a business card?
Nothing soft. Try a piece of tin cut out of a soup can or something.
Lazy_McDoesnothing
Folded up aluminum foil found in the kitchen works well.
Pierre
Oh alright... how do I stick this to the nut slot though? Glue as well?
I use the clear plastic from some sort of packaging - whatever's lying around when I need it. I don't think it'll compress too much.
Last time it was the packaging from "King of Shaves" shaving oil :D
I stuck it in with wood glue then stuck the nut on top of it, worked very well.
Pierre
That's a real good idea! I just bought some graphtech nuts and it came with a 0.075'' thick plastic packaging, which is just what I want. Perfect. Thanks!
sjwebb90
I have used these after a refret  on my locking nut and designed for the job and available Allparts
http://www.allparts.uk.com/nuts/locking-nuts-c-277_1_37_541_43.html
