Author Topic: Wiring a pickup for Series/Parallel or Coil Tap Operation.  (Read 135007 times)
Brow
« on: April 03, 2005, 11:41:02 PM »
Hi there.
I was just wondering how to wire a BK humbucker for series/parallel or Coil tap using a push/pull pot?
Also, what's the difference between wiring a pickup for series/parallel operation against coil tap?
Thanx for any info  :D
Craig
Tim
  • BKP
Re: Wiring a pickup for Series/Parallel or Coil Tap Operatio
« Reply #1 on: April 04, 2005, 07:58:49 AM »
Quote from: Brow
Hi there.
Craig
Hi Craig,
As long as you've go 4 conductor wire you can access all of the above options easily-I'll be posting wiring schematics for them very soon but both mods are easy to do with a DPDT push pull pot or switch.
Coil tapping or coil shunt grounds out one of the two coils in a humbucker giving you psuedo single coil tone.
Series operation is standard humbucking where the signal is routed through one coil and then the other.
Parallel tone is still humcancelling but produces a thinner tone as the signal is routed through both coils simultaneously-players like Paul gilbert use this a lot.
Tim
HJM
« Reply #2 on: April 04, 2005, 08:45:29 AM »
It's clearer if you have an understanding of how pickups work - have a look on teh web, try this site first
http://www.guitarnuts.com/wiring/pickups.php
Brow
« Reply #3 on: April 04, 2005, 05:29:20 PM »
Thanx for the replies Tim and HJM.
Quote from: Tim
Hi Craig,
Both humbuckers I have came with 4 Conductor wiring (Black Dog bridge and Riff Raff neck).
Is there anychance you'd be able to give me a brief run through of where the pickup wires would go in-order to achieve Series/Parallel switching using a Push/Pull pot?
Thanx for any info you can offer.
Craig
Brow
« Reply #4 on: April 05, 2005, 06:19:33 PM »
Got your email with the schematics Tim, thanx alot  :D
Craig
johnson
  • BKPs: Juggernaut - Black Dog - VhII
Re: Wiring a pickup for Series/Parallel or Coil Tap Operation.
« Reply #5 on: March 14, 2016, 04:45:22 PM »
The main differences there will be that BAREKNUCKLE will use a reverse magnet for the neck pickup, so you have to have reversed neck wiring also to get everything working in-phase. This is in order to be able to fit a regular PAF style pickup (one row of screws) the correct way around in the guitar and still get hum cancelling between the inner coils of bridge and neck together. Other brands simply use a symmetrical neck pickup and fit it in the guitar backwards.
Miss you Dime.
« Reply #6 on: March 14, 2016, 10:10:32 PM »
I think this wins the internet award for necrobump of the century!  First reply for over a decade!
There are a lot of schematics on the BKP site now
