I guess there must be
some difference (if you're Eric Johnson), but I have guitars wired both ways and the tone controls seem to work just as effectively either way.
I guess, if you're the experimenting type, you could try both and see if you hear any difference. Personally, once I've got a guitar wired up and working, the last thing I want to do is take it apart again! :lol:
If I'm replacing pickups, I usually leave the guitar wired the same way the manufacturer did it. If I'm wiring from scratch, I usually use the cap to connect the volume and tone pots - it's one less wire to solder.
