Quote from: WezV on February 17, 2009, 10:56:34 AM
i dont have to tell you guys to keep the wd40 away from electric bits do i? I have had a few people try to use it as pot cleaner :(
i know i cant talk you all out of using it but remember its not good for bare wood so if you are going to do it make sure your fretboard is nicely conditioned first so it wont be soaking it up and always spray it onto a cloth away from the guitar first.
personally i prefer not to have slippy strings
edit:
you may want to check this out as well
http://www.wd40company.com/files/pdf/msds-wd482671453.pdf
in particular the skin contact stuff
What sort of nob would try to use WD40 as a switch cleaner?!
I only did it once, 20-odd years ago - my sound engineer then explained what the two solvents were for and that knowledge helped me decide to use it on strings later.
Initially I used it just on the bridge area (strat) as part of the cleaning process after gigs - it helped reduce string breakage in the next gig/rehearsal.
Then I noticed that it cleaned the strings as well, and so (as long as I kept it off the bare rosewood) it would do the job I was using fast fret for.
I don't like "slippery strings" but I did need to clean them with something - that's all I was using fast fret for - I have horrendous sweat for killing metal parts on guitars.
Nowadays, not gigging, I don't use anything at all except a small dab of 3-in-1 oil on each saddle as I'm putting a new string on. When the string is up to tension, wipe off the excess. Everytime I play/touch one of my guitars, and I mean
everytime, I clean the strings thorougly with a dry rag (usually an old tea-towel).
I can't really remember for certain, but I do seem to recall what Twinfan's saying, Fast Fret did tend to leave a residue... but I also seem to remember that just putting it on with the applicator was only half of the advised procedure? :lol: (polishing it off again was the second part - at least that's what I did)
