Author Topic: nailbomb, warpig, or one crazy pig-90?  (Read 5502 times)
syr2012
« on: February 21, 2009, 11:52:08 PM »
My next project has me purchasing a fender tele with two humbuckers wired for a coil split (I'm a bit of a fender/squier junkie, they just feel right to me, even some of the squiers). I was going to take the MQ out of my strat and put it in the tele, but I don't really like dealing with braids that much, I like the MQ where it is, and it does seem like a bit of a waste of a coil split. Humbucker-wise, I'm only somewhat knowledgeable of the Nailbomb. I won't be undertaking this project for a few months, so I have some time to make an informed decision. Since humbuckers are two coils, I was wondering if it were possible to do something crazy like have one coil wound hotter than the other. I'm looking for something a bit hot and fat which will clean up nicely and even retain some bite when split. Is the Nailbomb (possibly 1-2k hotter) the right choice?
« Last Edit: March 03, 2009, 04:56:30 AM by syr2012 »
dheim
  • DON'TPANIC!
Re: nailbomb?
« Reply #1 on: February 22, 2009, 10:52:16 AM »
nailbombs (standard ones, i mean) DO clean up amazingly well and DO retain bite even when split... if you ask Tim i'm sure he will have no problem to wind asymmetrically your coils, or to tell you there's no need to do it!
too many? ;)
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
Re: nailbomb?
« Reply #2 on: February 22, 2009, 02:02:59 PM »
AFAIK the Nailbomb is already asymmetrically wound.
I see a rainbow rising
Look there on the horizon
And I'm coming home
syr2012
Re: nailbomb?
« Reply #3 on: February 25, 2009, 06:09:25 PM »
I'm thinking that there will be a change of plans. Instead of buying a new guitar, I'll probably just order a birdseye maple neck with ebony fretboard and stainless steel frets, a swamp ash body, have everything routed out and just install electronics myself. I might put a sustainer at the neck, so would a nailbomb at the bridge keep that bite and crunch, even when split (maybe wound a little hotter), or should I look for something else?
dheim
  • DON'TPANIC!
Re: nailbomb?
« Reply #4 on: February 26, 2009, 08:06:25 AM »
i don't know if they work well in your guitar, but if you want a thick and crunchy coil split sound you should consider a warpig too... they're surprisingly good for blues, when split...
too many? ;)
syr2012
Re: nailbomb, warpig, or one crazy pig-90?
« Reply #5 on: February 28, 2009, 03:54:05 AM »
Hmm, a warpig sounds nice, no matter what I get I'm firm on wanting a chrome cover with allen bolts, how do the bolts affect the sound, if at all?
I'm also thinking of a pig-90, with a coil tap. If I get a sustainer, the bridge will have to work well on its own, and I'm positive that a pig-90 could crunch and bite and burn...  :twisted:
« Last Edit: February 28, 2009, 03:55:45 AM by syr2012 »
dheim
  • DON'TPANIC!
« Reply #6 on: February 28, 2009, 10:23:06 AM »
i just got mine in neck and YES, it definitely does!
but pig90 is a single coil, you can't split it!
too many? ;)
maverickf1jockey
« Reply #7 on: February 28, 2009, 02:45:03 PM »
But it can be tapped, achieving a similar effect.
dheim
  • DON'TPANIC!
« Reply #8 on: February 28, 2009, 02:48:45 PM »
how, exactly?
too many? ;)
Madiac
« Reply #9 on: February 28, 2009, 04:12:47 PM »
how, exactly?
When you "tap" the single coil it shortens the coil, giving the effect of less winds. Didnt have any use for it on my pig90 though, could be because of incorrect wiring, but a tech did it. Thought the tap was to far along the coil so that the volume dropped to much.
dheim
  • DON'TPANIC!
« Reply #10 on: February 28, 2009, 04:16:23 PM »
it sounds like a risky business...
too many? ;)
« Reply #11 on: February 28, 2009, 04:41:48 PM »
Perhaps he took the wrong end of the tap?  In mine the volume doesn't really drop that much at all but the sound cleans up.
Madiac
« Reply #12 on: February 28, 2009, 04:54:25 PM »
Depends on how much distortion i have already. Sigh, cant be arsed, im selling that guitar anyway.
syr2012
« Reply #13 on: March 01, 2009, 07:59:21 PM »
Well, with Tim doing the tap, I trust that everything would go smoothly. For some reason (maybe the  :twisted: :twisted: within me), I'm interested in knowing about what a nailbomb would sound like wound to 17 or 18k instead of 16. I'll be using 1 meg volume pots and probably 500k push-pull tone pots (if I could find 1 meg, I'd work with those). I want allen bolts instead of screws (it would look cooler, plus keep me from screwing with 'em while I'm bored). How would bolts affect the sound?
syr2012
« Reply #14 on: March 05, 2009, 07:16:13 PM »
Just wondering... would it be possible to get a nailbomb with two sets of screw poles instead of one screw and one slug? How would that affect the sound? Would I be able to get it with allen bolts instead of screws?
