Author Topic: Tubes  (Read 2644 times)
Infliktor
Tubes
« on: February 23, 2009, 05:30:09 AM »
Tubes:
Poweramp:                         V1, V2:                 6L6GC matched set.
Preamp:                             V3 (input tube):  ECC 83 / 12AX7, FQ selected;
                                         V4, V5:                ECC 83 / 12AX7 selected;
                                         V6:                      ECC 83 / 12AX7, standard;
Which of these preamp tubes affect the tone
What does FQ selected mean?
What does selected mean?
AdamB
Re: Tubes
« Reply #1 on: February 23, 2009, 05:41:00 AM »
That input tube affects your tone the most. It's nearest to your input jack and all your signal goes through it. Pick a high quality tube for this
SG-X/Over wound Rebel Yell
Blue SG 61 Reissue/Cold Sweat
Egnater Mod 50
Matamp 4x12
hamfist
Re: Tubes
« Reply #2 on: February 23, 2009, 07:18:26 AM »
As Adam says, the input tube is traditionally considered to be the most important tone-wise, although in my experience, ALL the tubes can make a significant difference.
"Selected" just means that they have been chosen somehow using some criteria (probably being low noise) from a big batch from the factory (25% of which will be useless and thrown away).
Noise generated earlier on in the signal pathway is amplified by ALL gain stages, so becomes a problem manifesting as hiss through your speakers. That is why it is more critical to use lower noise resistors and tubes in the early gain stages.  However, a bit of tube noise generated in the last pre-amp gain stage , or in the Phase Inverter is hardly noticeable really so cheaper, more noisy, components are often used there to save money !
jpfamps
    • http://www.jpfamps.com
Re: Tubes
« Reply #3 on: February 23, 2009, 01:20:37 PM »
I would concur with the above. All the positions can make a difference.
I am very skeptical of "specially selected" valves, particularly if you aren't told what they are selected for. It seems a very good way of charging extra.
The only criterion it is worth testing for in a pre-amp valve is microphonics, although in my experience this doesn't always guarantee  that the selected valves will be microphony free.
Gizmo
Re: Tubes
« Reply #4 on: February 23, 2009, 04:07:09 PM »
i'm interested in tube advice too.
Picked up a cornford carrera last week. It currently has replacement El84 and El34 in it. Not sure they are special ones.
I wanted to get decent tubes to make the most of the amp. Was looking at putting in a decent El84 and a 6L6.
The pre amp valves can be changed for pretty much any type. Are they worth changing as well?
Any suggestions?
hamfist
Re: Tubes
« Reply #5 on: February 23, 2009, 04:13:14 PM »
Pre-amp tube changes usually make more of a tonal difference than power tube changes, unless you are running the amp well cranked most of the time.
