Author Topic: Denim Blue + Multiscale build thread?  (Read 70605 times)
Re: Denim Blue + Multiscale build thread?
« Reply #30 on: March 01, 2009, 02:50:20 PM »
just got the truss rod slot done and the fretboard stuck down
next job is to make the body wings... i have a huge slab of mahogany for this so need to do some careful cutting to see if i can get two sets of wings out of it - its huge but light and has an amazing tap tone,
GuiTony
    • guitar building blog
« Reply #31 on: March 01, 2009, 03:15:37 PM »
« Reply #32 on: March 01, 2009, 04:10:43 PM »
cutting went really well... gotta love new bandsaw blades - I reckon Roo's guitar had completely killed the old ones
the new ones cut so well i was able to take a very even 7mm slice off the face of each wing before smoothing the wings down on the thicknesser.  i only have a small bandsaw so this is unusual - it does open up options for backplates, matching mahogany ones for instance
get some pics in a bit
« Reply #33 on: March 01, 2009, 07:10:46 PM »
so, big ole hunk of mahogany marked out
there is a couple of knots and discoloured sections in the plank but the wings for this guitar are priority so get the best bit.
here it is all cut:
a whole other set of body wings available to me - albeit probably paint grade but definatly too nice to waste... got some thin slices off the wings for a cavity cover as well
so here are the wings
and me tapping the big plank before i started cutting
http://www.youtube.com/watch?v=QBXAvxSzDDs
GuiTony
« Reply #34 on: March 01, 2009, 07:34:12 PM »
That's what I like to hear  :D
That clip has the potential to become a cult classic!
Sounds almost hollow and not at all dull, so I'm guessing that it's a relatively light piece of wood.  We did right in deciding not to chamber it.  8)
« Reply #35 on: March 01, 2009, 07:47:36 PM »
yeah, obviously the mic on my camera doesnt capture everything i am hearing but this thing is clearly resonant and it is very light
thats just me tapping it with my knuckles - not a little drum stick or owt like that.
some people reckon it doesnt matter as much for the wings on a neck through but i am happier sticking a resonant piece onto the neck that will vibrate with it than i am something acousticly dull that will soak up the vibrations
« Reply #36 on: March 01, 2009, 07:51:31 PM »
Godammit, I'll never get that 4 seconds of my life back!    :rock:
 :wink:
« Reply #37 on: March 01, 2009, 07:56:11 PM »
i did say it was me tapping a big plank of wood... am i the only person that gets excited tapping big planks of wood ;)
« Reply #38 on: March 01, 2009, 07:59:50 PM »
I do more than tap my wood.
ANYWAYS!
Is that a Tele shape on the leftover block? The paint grade left over wood.
« Reply #39 on: March 01, 2009, 08:23:06 PM »
yeah but that was just me grabbing the nearest ordinary shape template to see how much wood was available
hooglebug
    • afguitars.co.uk
« Reply #40 on: March 01, 2009, 08:34:14 PM »
haha i spend hours in the woodyard doing it. people look at you like you're a mental
« Reply #41 on: March 02, 2009, 03:07:02 AM »
These pics are right after saw, without sanding? :o
« Reply #42 on: March 02, 2009, 03:52:38 AM »
You can make me a Telecaster then! :D
« Reply #43 on: March 02, 2009, 08:28:09 AM »
nope!  the body blank was 1 3/4" thick but obviously i am adding the maple top which is about 8mm +1mm for a accent veneer.  so i sliced of 7mm and took the last 2mm off with a router  thicknesser and sanded smooth.
i could make a telecaster with those parts but they are not wide enough for a whole body so it would need something in the middle - i will most likely use them as another set of through neck body wings.. i did manage to save quite a bit of an outline so i may actually be closer to a full body blank than i thought, i will check again before cutting anything
« Reply #44 on: March 02, 2009, 02:13:19 PM »
A neck-thru Tele, that's extreme, lol
