What cover would look best on my guitar? :)
Started by Jaekae, February 28, 2009, 06:20:56 PM
Jaekae
Im having big problems deciding  :P im getting a set of calibrated nailbombs
im thinking of battle worn black, normal black, nickel, or maby chrome? Is there any other good options?
I'm going to be unhelpful and say you might have trouble squeezing covered pickups into those routings.
I'd stick with uncovered black - or maybe zebra.
Fourth Feline
#2
Look up 'Burnt Chrome ' in the main B.K.P Gallery,  flarings of blue across the surface.  Philly has a very good point about checking that they would fit though ...  :)
Jaekae
Quote from: Philly Q on February 28, 2009, 07:45:15 PM
do you maby got some measurements of the covered versions? its a bit more space than it looks like on that picture
I don't know specific measurements, but the covers are big enough to go over the baseplate, so they make the whole pickup a bit bigger.
And with those direct-mounted pickups they usually make the hole quite tight so the pickup can't move around.
I'm not trying to put you off getting covers, just something to think about - you might need to do a little routing.
Perhaps cream...
The black battle worn will look cool...
Lazy_McDoesnothing
Black cover with double row of black allens i think. 8)
Make sure to specify the triangular tabs, shorter polepieces, and a low profile design for Ibanez's shallow routing!
Jaekae
#7
here you see how much space there is, think it would fit if i tell them its for this guitar?
yellowv
A covered Nailbomb would not fit into the direct mount route on my Ibby which should have the same size route as your RGA.
Quote from: Lazy_McDoesnothing on February 28, 2009, 08:31:04 PM
Sounds promising...
Quote from: yellowv on February 28, 2009, 11:04:47 PM
Then again, maybe not.
It's up to you.  Looking at the picture, I think covers would be a very tight fit, if they fit at all.  I had to slightly rout the cavity on my SG to get my Riff Raff to fit, and I'm not 100% sure my covered CS set is going to fit in my PRS.
Lazy_McDoesnothing
Quote from: Philly Q on March 01, 2009, 12:18:14 AM
Sounds promising...
Yeah I was talking in terms of depth.  I don't have covered pickups in any of my Ibanez's so I can't help there.  I just know when I fitted the Painkiller set in my 7 string RG I had to grind the pole pieces a mm or two.  They were even longer than the (short)legs.  I know it wasn't a good idea and the pickups should have been sent back for different pole pieces but I couldn't wait. :oops:  I also had to bend out the legs to line up with the previous holes because I didn't feel like drilling new ones.  But they're fitted and everything works and sounds great!
Madiac
As some other lads already said, burnt chrome, will look awesome on blue guitars IMO.
Adam.M
First i have to say, that is one GORGEOUS ibanez!
I personally wouldn't be putting covers on it, but burnt chrome would look sweet, as would just chrome to match the bridge.
Jaekae
Quote from: Adam.M on March 01, 2009, 04:32:37 AM
yea its my dream guitar :D it plays like a hot chick on a sunny beach in the carribean. And sounds amazing even though the stock pickups are only decent. SO cant wait to get some BKPs in it.
btw do anyone know if they could do "custom" uncovered? Like all black, with black screws etc.
