Preamp Valves - matched?
Started by Tricalibur, March 02, 2009, 12:14:33 AM
Tricalibur
So I own two vintage Mullard 12AX7's which I believe are a matched set. I want to put them into my Matamp head but I need to buy one more to complete the preamp stage. Do preamp tubes need to be a matched set to sound the best, and do I have to drain the voltage out of the amp before I remove the old tubes?
<The Warpigs Are Coming, Hide your Children... and bring BBQ Sauce>
martinw
No, and No. Just turn the amp off.
Custom Built Amps:
www.mjwamps.com
AdamB
Only the power amp valves you need to have matched to get the best out of them. Pre amp valves, you can mix and match, low gain, high gain, whatever you like :D
SG-X/Over wound Rebel Yell
Blue SG 61 Reissue/Cold Sweat
Egnater Mod 50
Matamp 4x12
JamesHealey
yea pre-amp tubes are cathode biased which means it doesn't matter you can just about drop anything in there and it'll work, yet ideally in a perfect world u'd change the anode resistor and cathode resistor for new types of pre-amp tube like 12AU7 to get the perfect bias.. but who the hell does that?
Just plug and play my friend.
the_bleeding
since preamp tubes amplify by cascading each stage sequentially, matched bias doesnt matter.
Matched bias only matters in the output section of Push/pull amps, because it splits your signal in 2, and amplifies the negative and positive sides seperately, and you want those sides amplified equally.
