Amp taken care of, now... Telecaster!
Started by Pierre, March 04, 2009, 11:17:13 PM
Pierre
Yep, tis twang time... Say I had up to £250 to spend on a Telecaster... what would y'all advise? Second hand MIM seems like the best bet so far... I'd upgrade it with pickups and a 5 way megaswitch.
Oh also, are MIMs routed under the pickguard..? I'd make it SSS (Tele, Strat, Strat) with the switch wired:
Bridge/bridge + middle/bridge + neck/neck + middle/neck, with a push pull to make position 3 in series...
Squier Classic Vibe is good value, and already routed for a neck humbucker  ;)
Pierre
Good call on these... I could probably get a second hand MIM for this price, but they're still in the running. Never putting a neck bucker on a Tele though  :? :lol:
Quote from: Pierre on March 04, 2009, 11:17:13 PM
Would that wiring need a double-wafer superswitch?  I'm not sure it would fit in a Tele control cavity.
marantz1300
MIM's are good,mine wasn't swimming pool routed.So it might mean getting the old hammer and chisel out.But you will get Fender on the Headstock. There was a MIJ on Gumtree this week for £250.
jpfamps
Quote from: Pierre on March 04, 2009, 11:20:51 PM
Worked OK for Albert Collins!
Pierre
Well I think I'll keep it simple, get a MIM, a 4 way switch (got one already, woot) and wire it as a Tele with added neck + bridge in series. Upgrade the bridge and saddles along the way too. Thanks!
+1 on the Squier CV Tele.
Just as good, maybe even better than the MIM's.
Order where you can get them the cheapest, the quality is very consistent.
Quote from: Twinfan on March 04, 2009, 11:18:58 PM
Its routed for a humbucker at the neck?
second-hand MIJ tokai. if you're lucky, you can pick up one of the newer ones (with modified headstock) for around £250. EDIT: it's probably routed like a vintage tele, though, if that's a problem.
i haven't tried the classic vibes yet, though. :(
Quote from: dave_mc on March 05, 2009, 05:42:37 PM
You haven't tried a lot Dave, being in NI I doubt it'll be anytime soon :P Start moving!
Ted 'N' Leo
I have one of these, it is a fantastic guitar. Built to a very high standard.
I didn't know it was routed for a humbucker, now im thinking about a MQ for it!
