Author Topic: Cheap footpedal tuner  (Read 3515 times)
  • Truly bad since 1972
« on: March 10, 2009, 03:04:02 PM »
Need a cheap one to go inline with my other pedal effects
Re: Cheap footpedal tuner
« Reply #1 on: March 10, 2009, 03:26:35 PM »
How cheap?
Boss TU-2
Korg DT-10 (my tuner of choice)
Korg Pitchblack
They're your main guys, unless you go peanuts cheap like a Danelectro tuner?
« Reply #2 on: March 10, 2009, 03:46:56 PM »
ta..thats my kinda cheap the korg and boss
« Reply #3 on: March 10, 2009, 03:48:50 PM »
korg pitchblack is meant to be true bypass... its a great pedal - i have one
Davey
« Reply #4 on: March 10, 2009, 03:54:57 PM »
i'm gonna go for the Korg Pitchblack, when i get to some money
« Reply #5 on: March 10, 2009, 04:19:20 PM »
The DT-10 is buffered, which is good if it's your first pedal...
Oli
« Reply #6 on: March 10, 2009, 04:29:42 PM »
Korg Pitchblack user here, it's great (and more accurate than the Boss too!) :)
markofled
« Reply #7 on: March 10, 2009, 04:39:07 PM »
planet waves do one which is true bypass and well constructed. Ive found it very reliable
« Reply #8 on: March 10, 2009, 05:20:01 PM »
I got my Pitchblack+ new and boxed off of eBay for £55, quite cheap for what its actual worth is
« Reply #9 on: March 10, 2009, 05:21:12 PM »
The new Digitech Hardwire tuner looks good.  About £10 more than the TU-2 or Pitchblack though:
http://www.digitech.com/products/Hardwire/HW_Tuner.php
tomjackson
« Reply #10 on: March 10, 2009, 08:34:30 PM »
The pitchblack is great, very good to read on stage and quick to find the notes.
I don't know if it's proper true bypass as that would require a 3DPDT switch but the switch on my tuner feels more like just a mechanically controlled micro switch.  There's no pop like a true mechanical switch.
Nonetheless there is no signal degregation when bypassed and it's built like a tank....
Frank_C
« Reply #11 on: March 12, 2009, 07:11:29 PM »
£55??!!??
i got my Korg pitch black for £45 off of Hot Rox UK
« Reply #12 on: March 12, 2009, 07:14:26 PM »
Pitchblack+
The more accurate one :P
Frank_C
« Reply #13 on: March 12, 2009, 07:19:21 PM »
ahhh ok
haha didnt see the little + in there :P
so yeah £55 is good!
« Last Edit: March 12, 2009, 07:23:12 PM by Frank_C »
m0jo
« Reply #14 on: March 18, 2009, 01:54:07 PM »
Korg Pitchblack definitly, better than the Boss and not unnessecary huge like the DT-10
You're right tomjackson, in that it is an actuator switching a microswitch, but;
The Pitchblack is true bypass, the microswitch switches a relais that switches the pedal true bypass, just as good as mechanical TB. ;) But cheaper to make I guess.
edit: By the way, the + isn't more accurate in (half) strobe mode, only in standard mode.
« Last Edit: March 18, 2009, 01:57:30 PM by m0jo »
MXG custom '60s fiesta red strat
Ibanez S470DXQM
-->shiteload of pedals-->
Laney VC100
