Fixed bridges vs trems for bending etc.
Started by Madiac, March 10, 2009, 07:17:17 PM
Madiac
Ill start by saying that i love to use alot of expression with the lefthand (wide bends, vibratos and whatnot), ALOT of them are included in my playing, very iommi/blues influenced. Ive considered a floyd on my next guitar, but i suposse this might be wrong? I heard you bend the whole trem and strings fall out of tune etc. Is this true with all trems? or only Floyd style, the ones you can do divebombs and really strong pulls? Is a fixed bridge ultimate for people like me?
I think it happens to all trems (unless they're lockable?).
Bending one string will flatten the others while you're bending it. But this will only be an issue if you want to play the other strings while bending one...
For example, if you whack the bass E, leave it ringing, and then bend a D up to E elsewhere - that bass E goes flat.
I quite like trems (for gentle Hank Marvin type stuff :lol:) but I just can't use a floating bridge because I do multi-bends, country/blues type stuff...
The only way you'll know is if you give it a go - see if you can try a guitar with a trem on, try to ignore the trem and play your usual style and see how you get on... :D
Madiac
Hm, well, i really could live without one, i mean, if it is a compromise for left hand expression, even in the least, i think ill stick to fixed bridges^^
yeah, as andy says, if it's a floating trem, bending is going to knock the other strings sharp. Can kind of counteract it with more springs, but then that affects how the trem feels.
you can learn to overcome the problem with practice... i play a lot of lead and use trems too. i also use fixed bridge guitars, though, and they are a little easier for double-stop bends etc.
up to you, really. i mean, it only really affects things if you bend on one string and have to hit a note on another string before you've released the bend.
Madiac
Quote from: dave_mc on March 10, 2009, 07:49:25 PM
Yeah, i do all kinds of bends and stuff, as i said, i love left hand expression, so i might be better of. Maybe im better of then, i dont really find use for a standard trem that can do the lighter stuff, since i do that stuff with the lefthand.
I'm a similar player to you.  I play loads of double stops, lots of bends and vibrato, very Chuck Berry/Angus Young influenced.  I'm also very heavy handed when I play, especially live.  I really dig in and hit the strings.  My right hand is all over the place like Pete Townsend, and my left hand is always doing most of the work.
I ditched using a trem live just for a couple of tracks, and now I'm sticking to fixed bridges.  I didn't want to adjust my style and lose what made my playing 'me'.
Sounds like you need to buy a cheap vibrato guitar (used Squier Strat?) and see how you get on with it...
Matt77
Kahler trem systems are a possible avenue to explore as the other strings don't move as much when you bend another
Wez brought a Kahler equiped guitar with him to the meet in Manchester.
Perhaps he can give an opinion / bit more info  ?
i should have added, i play lead all the time- more than rhythm. it doesn't bother satch, vai etc. either. then again, there are plenty of lead players who don't like trems. i don't think it's a question of whether you do bends or not, it's a question (as twinfan said) of preference. :)
Quote from: Matt77 on March 10, 2009, 08:50:44 PM
I'm not sure, I haven't used a Kahler for a long time but I think the bar used to dip when I bent the strings.  It is possible to get Kahler models with a little locking switch, but it's not something to flick on and off mid-song, of course.
You can set up a Fender trem (or even a Floyd) with extra spring tension so it sits flat on the body and doesn't move when you bend strings.  But it means you have to be a bit more heavy-handed with the bar when you want to use it.
And you can get gadgets like the Tremol-No and Tremsetter which let you lock the trem and/or reduce the going-out-of-tune problem.  They do change the feel of the trem though (well, the Tremsetter does for sure).
Pete24v
a device like a tremstetter or tremol-no may give you the best of both worlds...
The arm on my Kahler doesn't bend down when I bend. 10-46 on 24.75" scale length FWIW
Quote from: Will on March 10, 2009, 11:05:58 PM
Same strings and scale length as me.  Maybe it's something to do with the setup - I know you have the stud mount version, mine was a flatmount with the saddles up really high to get the right string height.
Or maybe they've refined something about the design since the '80s.  :?  :lol:
Come to think of it, when the flatmount was on my LP, the arm did bend with it. Interesting there.
Both of the Kahler's I have used have been 80s models, Wez now has the Flyer flatmount (I think it went on one of his earlier Ravelle inspired shapes)
The rollers are also very high on the studmount, and the bridge is angled backwards, increasing the effect of this too.
I would advise to go out and try a well set up Kahler somewhere. Not going to be many about though
Copperhead
If you install a Floyd to be dive-only, you set the springs heavy enough that the bridge does not move when bending. Another benefit is you can use a D-Tuna.
Free floating trems will hamper your vibrato and heavy bends, unless you get in the habit of pulling up on the trem as you bend, ala Jeff Beck.
Zaned
I have no problems with finger vibrato, with a vintage style trem bridge set to float. It does drop the pitch of other strings when you bend one. You can compensate for it a bit, but of course it's a compromise..as is also a trem bridge that has been setup for dive-only action. With that, you'll lose the bar vibrato. I've tried both. You'll probably lose some tuning stability (with trem use), if you set a vintage style bridge flush to the body.
I believe Steve Vai uses or at least HAS used a device like tremsetter. With that, the guitar doesn't drop pitch while bending strings (I don't know HOW far you can bend before it releases), but naturally, it'll change the feel of the trem. A natural sounding bar vibrato is probably a bit trickier, I haven't tried one to be honest.
And when playing with a fixed bridge equipped guitar, I don't have to worry about those kinds of things. Not the good or the bad :D It's all about choosing the most appealing compromise. And owning different kinds of guitars  8)
-Zaned
Paths are for followers.
