Author Topic: Yep its another one of those post praising BKPs  (Read 2401 times)
PESIMAX
« on: March 14, 2009, 05:55:22 PM »
Well as an obsessive collector of guitar etc (isn't everyone) I've constantly changed pickups and bought new amps and guitars. I've gone through Rickenbackers, Burns, mosrite,Strats, Les Pauls etc and never found something that i really was happy with...untill i decided to spend some money on these pickups. I had a 72 reissue that i used to use at the end of gigs to throw about (on the last track i play a solo and ripp of all the strings during it etc), so after one gig, i managed to destroy the input jack and some wiring came loose...so i though might as well give the pickups a try.
I bought Riff Raff for the neck and brown sugar for the bridge and i've finally got tone I was looking for, I tested it on a cheap (awful sounding) no name practice amp to start with...and it sounds pretty good, good enough to gig and maybe record within a mix. Then plugged it into the Jcm800 and it sang, I was playing like i never have before. I normally stick to rhythem but the pickups give you the confidence to hammer out a solo. I also put in a coil tap just do add a different tone, and it was almost strat like.
I'll be putting up some recordings and pictures soon. The only question left now is.....which pickups should i get for my other guitars?
Gx
lulusg
Re: Yep its another one of those post praising BKPs
« Reply #1 on: March 14, 2009, 09:29:34 PM »
Hi there!! and welcome to the forum!!! Which guitars are we taking about? Lot's of people here to help you out...
Just passing by
Fourth Feline
« Reply #2 on: March 14, 2009, 09:31:42 PM »
+ 1 to that !
dheim
  • DON'TPANIC!
« Reply #3 on: March 16, 2009, 08:36:35 AM »
if you're a real obsessive-compulsive guitar collector like many on this forum (ahem... i think it applies to me too... :)) a nice policy could be (and in the end you'll discover you actually did it!) to buy EVERY BKP in your category of choice to strengthen the differencies between your guitars...
too many? ;)
