Author Topic: Modellers for recording  (Read 2580 times)
BloodMountain
« on: March 16, 2009, 05:21:53 PM »
sup
I recently tried out a nice easy way of recording in the form of one of those Edirol USB interfaces and it worked really well! i was using it in conjunction with garageband which was good at first until i realised the distortions are all trash.
so, i was wondering if there are any good multi-effects modellers that work nicely with USB interfaces
that is, if they can simply be placed in between the guitar and interface. can they?
cheers, BM
Denim n Leather
Re: Modellers for recording
« Reply #1 on: March 16, 2009, 05:32:40 PM »
They sure can!
You can also use modeling software as a plugin with your DAW software.
« Reply #2 on: March 16, 2009, 05:38:48 PM »
I like the Amplitube 2 modelling plugin, it takes a while to find out what sounds good but once you've figured it all out you can get some pretty good tones from it.
BloodMountain
« Reply #3 on: March 16, 2009, 05:43:01 PM »
cheers guys!
hey Tom, is there a demo version available or not? don't want to go buying stuff that i hate y'know.
edit: dw man, just found out you can for 10 days!
« Last Edit: March 16, 2009, 05:55:30 PM by BloodMountain »
  • Truly bad since 1972
« Reply #4 on: March 16, 2009, 06:01:24 PM »
Revalver..comp based or Tonelab Le outboard
BloodMountain
« Reply #5 on: March 16, 2009, 06:11:17 PM »
ReValver looks damn good, thanks for the heads up.
Are there any advantages of using a modeller over software?
Denim n Leather
« Reply #6 on: March 16, 2009, 06:40:34 PM »
A modeler won't tax your computer's resources. If you have a decent machine, however, it's a moot point, and might actually sound better!
BloodMountain
« Reply #7 on: March 16, 2009, 06:59:56 PM »
hah, no I don't really have a decent machine. It can barely handle Ableton Live with EZdrummer plugin...
i guess a modeller would be better then. I've heard a lot about the Tonelab LE so i think i should check it out sometime.
« Reply #8 on: March 16, 2009, 08:25:09 PM »
If you're going the outboard route, I'd definitely recommend the Tonelab LE. I have a POD XTLive as well, but I only really use it for recording bass now that I have the Tonelab. The reason I like the Tonelab is because it seems better for the just-breaking-up fender/vox/early-marshall type tones than the POD is.
See if you can find one to try - I bought mine after trying it for an hour or so, but I'd pretty much decided after a few minutes :D
« Reply #9 on: March 16, 2009, 10:52:18 PM »
yeah pods just don't have the same warmth as the "le" for me..had the xt maxed out..before buying Le
lifted
« Reply #10 on: March 19, 2009, 04:05:03 AM »
You can't beat the tonelab
« Last Edit: March 19, 2009, 04:13:22 AM by lifted »
Irish Tour/ Mule Set,    Apache Set... in Strats .... Nailbomb Bridge,Cold Sweat Neck in Ibanez S540
Lew
« Reply #11 on: March 20, 2009, 12:49:10 AM »
I'm using WavesGTR solo for my clean/overdrive tones and effects and GuitarRig3 for highgain.
I have Amplitube2 too, but not impressed.
« Last Edit: March 20, 2009, 12:51:26 AM by Lew!! »
