Author Topic: Tweaking questions  (Read 1873 times)
Bradock PI
Tweaking questions
« on: March 17, 2009, 09:25:53 PM »
Tusq vs Bone nut to replace plastic worthwhile and which?
Is an upgrade from a mid level korean tune-o-matic bridge worthwhile or a waste of money on a guitar like the Daisy Rock - Rock Candy Classic - which would you go for?
What about changin saddles?
I am guessing headgear only worth changin' if it's not holding tunes?
What are your top tweaks?
Stevepage
Re: Tweaking questions
« Reply #1 on: March 17, 2009, 09:31:32 PM »
I had a bone nut fitted to my Strat after it had a refret. There's no difference in tone, but theres was a big difference in tuning stability. It's held it's tuning much better since then. I would like the Earvana nut installed as I hear it helps with intonation
tomjackson
« Reply #2 on: March 17, 2009, 09:34:55 PM »
I'd go with Tusq, just because it's completely uniform and easy to work with.
It should improve both tuning (as long as cut right, but they sell pre-cut ones) and tone in the open positions.
As for the bridge, the answer is yes, an upgrade may make a subtle improvement.  I treally depends on whether you want to spend the money :D
