Author Topic: Dumb Question about Tele Bridge  (Read 5170 times)
« on: March 21, 2009, 09:30:35 AM »
Does a tele bridge need to be grounded?  I've grounded a strat bridge before, and a TOM...  Do I just solder a wire directly to the underside of the bridge then to the back of the volume pot?
Mark.
Tellboy
Re: Dumb Question about Tele Bridge
« Reply #1 on: March 21, 2009, 09:49:50 AM »
Yes it will need to be grounded. I think my teles have a hole under the bridgeplate  and a piece of bare wire connected to the volume pot. The wire is wound in a 'curly whirly' at the end and the bridge plate just sits on it when it is screwed down - no need to solder providing everything is clean and has a good contact.
« Last Edit: March 21, 2009, 09:58:12 AM by Tellboy »
« Reply #2 on: March 21, 2009, 10:07:52 AM »
Cheers, bud.
Mark.
« Reply #3 on: March 21, 2009, 11:15:38 AM »
Agreed, but having said that, you will find (vintage-style) Teles with no ground wire or hole under the bridge.
That's because if it's the type of Tele pickup with a metal baseplate, the baseplate is grounded and connected to the metal bridge by metal screws... so the strings are grounded via the pickup baseplate.
« Reply #4 on: March 21, 2009, 12:28:47 PM »
+1 to all
Bridges/strings need grounding.
But if your tele bridge pickup has a metal baseplate you don't need an extra wire.
tomjackson
« Reply #5 on: March 28, 2009, 09:31:23 AM »
I just rubbed some of the finish off the back of the bridge and put a bare wire underneath when I screwed the bridge down, then connected to ground.  That works fine....
« Reply #6 on: March 28, 2009, 09:42:06 AM »
You are a walking guitar encyclopedia Phil!
« Reply #7 on: March 28, 2009, 10:21:40 AM »
Thanks CJ, but if only that also applied to my playing :( .   I'd like to be a walking riff-opedia.  :)
« Reply #8 on: March 28, 2009, 10:38:05 PM »
Thanks for all the replies, chaps -- Tele is now all built (earth wire shoved under the bridge, just in case), and all sounding damn fine!!!
Mark.
Fourth Feline
« Reply #9 on: March 28, 2009, 10:59:12 PM »
Mark.
I also had to add a (tailpiece ) earthing wire to my recent Jazz guitar aquisition . With a ' floating' wooden bridge ,  the tailpiece / strings needed earthing to the back of a pot for optimum results.
