good noise gate
Started by dheim, March 21, 2009, 08:34:23 PM
dheim
i'm looking for a good rack mounted noise gate... something not too obtrusive in terms of tone and dynamics. and of course true bypass. any idea?
too many? ;)
ISP decimator has a rack version.
Pedal decimator does its job superbly, though, I'd just get that.
maverickf1jockey
Decimator Pro Rack G?
I don't know anything much about rackmount gear.
TC electronics could have something good...
BBE Sonic Maximiser have a noise reduction circuit on their rack mounted units.
I love the decimator prorackG.
2 channel, one for before the amp, one for the effects loop, and it takes your input signal and preserves that in Channel 2 so it's easier to dial out amp noise, 50/60Hz hum and any noise from other pedals.
A bit pricey, but I don't think I came across anything else that comes even remotely close to this when I was searching for noise reduction systems!
BTW Noise Gates are something a little different, and you probably want noise reduction instead (ie filters out the cr@p but leaves your signal alone).
Hope this helps,
Roo
shaman
dheim
i just bought a decimator pedal (well, i ordered it from the USA, of course there's no way to get one of those in this shitety country)... i didn't think there was such a difference in price between pedal and rack!
too many? ;)
You wont be dissapointed with the pedal. I dont really see how the rack can be better - the pedal doesnt change your sound in the least, it opens and closes spectacularly quickly, and generally all round does its job perfectly. Good call. I swear by mine - good enough at its job that I've been out of the noise gate market since I got it (about 4 years ago)
dheim
i asked for rack because i don't want to have too many pedals around... but i'll keep it inside my flight case, now i have just one 1U effect in a 3U case! if i'll set it for a light reduction i'll be able to use it even for solos, i think...
too many? ;)
Yes you can do that. At min reduction, it does nothing. At max, it doesnt even let a full signal through.
Fourth Feline
Quote from: dheim on March 22, 2009, 05:44:19 PM
i just bought a decimator pedal (well, i ordered it from the USA, of course there's no way to get one of those in this shiteety country)... i didn't think there was such a difference in price between pedal and rack!
I notice that 'Highly Strung' are still doing the pedals and rack mount range online in the U.K.  I bought my  'basic' Decimator pedal from them a year or so back.  :)
FWIW, the pedal is single channel, and therefore can't differentiate between signal and noise in the effects loop. I find the rack unit unfeasibly good at its job, and - given the exceptional quality of this - I expect the pedal to be just as good (just not covering the 2 channels, which I particularly wanted to help clean up noise in the effects loop as well as in front of the amp!). You'll find it superb, I'm sure! :)
Roo
yellowv
I use a Decimator pedal and it is great. The Pro Rack G is even better.
