Seems Brian Wampler from
Indyguitarist.com is going into the pedal kit business
http://www.buildyourownpedal.comThere are some descriptions of pedals below which will be available as kits
Can you guess which pedals they are copies of
Retro ScreamerThe Retro Screamer is a perfect reproduction of a classic overdrive in a green box. This is the most popular overdrive in the world for good reason. We supply multiple mod sheets to help you explore the many variances of this pedal existing in the boutique world today. We selected what we felt were the most effective and most musical mods available which will allow you to turn your pedal into literally one of dozens of popular boutique pedals which sell for hundreds of dollars.
Ratical DistortionThe Ratical distortion pedal is a recreation of a classic pedal in a black box. This has become a very popular pedal for modern boutiquers to modify. We supply several of the best known mods around today. Included is the famed '308' chip that made the original so sought after by some of the greatest guitarists in the world.
Supervisor OD-UnoThe Supervisor OD-Uno is a recreation of a classic OD. Many Boss pedals made for great platforms for modification. We supply what we feel are the most effective mods for this pedal
Supervisor DS-Uno
The Supervisor DS-Uno is a recreation of another classic. This is also one of the classic circuits prime for modification to achieve optimal distortion tones. We supply several of the best mods available for this circuit. The DS-1 has long been used by pro guitarists such as Joe Satriani to achieve the monster tone he gets.
The Sheriff BallbreakerThe Sheriff Ballbreaker is a classic circuit that has had many boutique clones in this modern era. We feel that it is a great starting point for creating and even greater pedal. Our mods capture the true essence of this circuit and bring it to a whole nuva level. One of the great 'kings of tone' in the effect pedal world was designed around this circuit, you are now able to modify this circuit into your own tonal king.
The Sheriff Speed BrakeThe Sheriff Speedbrake is also a classic circuit that was great in its time. We felt it could be improved substantially. Our mods make this the pedal what it needs to be.
The Sherriff RipperThe Sheriff Ripper was an early calling for metal tones but we feel it does not quite hit the mark for modern high gain. Our mods will bring you into the current age of metal.
Mixer Distortion MasThe Mixer Distortion Mas is a classic circuit used by many great players in the past. We always felt it was not worthy of the name distortion. Try our mods and hear this pedal come alive. Great guitarists such as Randy Rhoads used the original version of this pedal to great advantage, our mods can give you this same great tone that he was able to get out of the pedal.
Supervisor OD-TresThe Supervisor OD-Tres is yet another recreation of a classic circuit. We feel our mods make this pedal a contender to any pedal to date.
Nobleman ODR UnoThe Nobleman ODR Uno is a recreation of a pedal that has rarely been seen in the modern boutique world. Widely known as one of the best OD's ever made and commonly used by the Nashville session katz. The original is too noisy and does not have true bypass making it a tone sucker. Try our mods and you may just find the best OD made. Included are the best parts available making this tonally superior in every way to the famed Nashville Overdrive.
Five O'Clock ShadowThe Five O'Clock Shadow is a recreation of the most famous smiling Fuzz. We supply some mods to an already great sounding pedal. This pedal gave a certain left handed guitar god his mojo.
The Fat KittyThe Fat Kitty is a recreation of a classic wooly fuzz. We put our spin on this circuit to give it a more useable and musical sound. Long hailed as the 'sound of the smashing pumpkins', our mods give you the exact specs used to get that tone.
The OctopusHendrix anyone? The common complaint about the Octave type pedal was the fact that you were stuck in that sound. Our mods provide a foot switchable Octave up so you can use the fuzz side on its own.
JFET boosterJust a little boost for your boosting needs... the JFET is the solid state version of a 12ax7 tube gain stage
Buffer BoosterThe buffer Booster keeps your large pedal boards rockin with no loss of signal or tone. Using the same circuitboard, you can either build an extremely accurate opamp based buffer (featuring ultra-low impedance) or high-headroom opamp booster.
Wampler "Plexidrive" OverdriveWampler Pedals designed this pedal to emulate Marshall JTM-45 type of tones, now you can get everything you need to build it yourself.
Built as a cross between a "Marshall 18" and a JTM45, this pedal was designed to sound and react eerily similar to the famed Marshall Amp. Includes a switch that enables it to sound great with either clean sparkly amps (like fender twins, Vox, etc.) to darker beefier amps (like Vintage Marshalls, Mesa Boogies, etc).
Wampler "Plextortion" distortion pedalOne of Wampler Pedals most sought after distortion pedals - the original "plextortion" pedal was designed to sound like and react similar to a Marshall JCM800. This is an exact clone, part for part.
Soundclips:
http://www.indyguitarist.com/soundclips2/plextortion-207-vox.mp3Youtube:
http://www.youtube.com/watch?v=leLJUpQHqiA
Wampler "Cranked AC" overdriveThe Cranked AC is a pedal that was designed to emulate a cranked Vox ac-30 in order to achieve tones similar to Brian May's tone.
Specs:
* High grade film capacitors and resistors picked for their superior sound and response
* Very pick responsive - play light and it's clean, dig into the strings and it gets nice and dirty
* Very light overdrive all the way to near fuzz-like when at max settings
