Author Topic: Picks!  (Read 10860 times)
Re: Picks!
« Reply #30 on: March 25, 2009, 03:15:10 PM »
Ultex Jazz IIIs for me.  Very stiff which is great, as I usually bend picks into a banana shape after 5 mins of playing...
Re: Picks!
« Reply #31 on: March 25, 2009, 05:47:07 PM »
i use dunlop gator grips because i don't drop them (often), and they don't seem to wear out so quickly.
Re: Picks!
« Reply #32 on: March 25, 2009, 06:33:03 PM »
Am I the only one who finds the BKP free ones to have really rough edges after a few minutes of playing? I find them really "sticky" to pick with if that makes sense.
I do find that they wear the fastest out of the ones I use - and depending on what I've been playing, they go exactly how you describe - mebbe we're a bit too aggressive with them? :lol: But I do find the rough bit tends to wear down pretty quickly for me :lol:
I quite like the tone they produce, which was why I ordered a bunch...
But basically, I like nylon picks - they give me good bite to my tone, they're very expressive for me because they respond to lighter/heavier touch well, they wear slowly and consistently, they usually have a grip, they're nicer to chew on (! :roll:), when I was gigging I found I got less string-breakage with them... etc, etc
But I've found recently that harder plastics and mock tortoise-shell types can produce much better tones for some things where my nylon picks just give me a good compromise. But what the harder picks cannot do for me is the wide range of hard to mellow tones that a nylon gives me, they just seem more of a one trick pony in my hands. If I want that trick, that's the pony to use... But when recording a while back, I found that for all lead work I had to revert to nylon - none of the others had the requisite attack I was after or were enabling me produce enough "expression" in my playing.
I'm sure others can make the harder plastics more expressive than they can nylon - but that's the way it works for me...
It's making me wonder Tom - also based on the tones you use on recordings - have you ever tried nylon? You might get on with it...
« Last Edit: March 25, 2009, 06:35:35 PM by AndyR »
Simon D
Re: Picks!
« Reply #33 on: March 25, 2009, 06:45:27 PM »
1mm Dunlop Tortex for me. I have been experimenting with Dunlop Jazz IIIs a bit, and I find them fine for lead work, but don't like them so much for playing riffs/chords.
Warpigs.
Fourth Feline
Re: Picks!
« Reply #34 on: March 25, 2009, 07:33:44 PM »
Strangely enough, I usually found the opposite;  in that a new B.K.P ( D'andrea ? ) pick usually took a couple of days of playing, to round / smooth / polish the edges a bit for me.   I have subsequently noticed ( and this is why I bought spares at the time  ) - that compared to the Planet Waves celluloid of about the same gauge / material - B.K.P sounded  a touch more muted / softer when 'worn in'.  Unless I just got picks from a different batch a year or two  back ?
As mentioned before though, a change in style / pickups / tonal requirement eventually made the B.K.P and Planet Waves sound a bit generic compared to a smooooooth  Dunlop Jazz 205 or Smoooth , glassy , articulate and huge sounding Agate picks.
Be warned ( in a nice way ) -  B.K.P. Manhattans in a hollow bodied guitar, played cleanly -  make every little difference suddenly sound like a big difference.
« Last Edit: March 25, 2009, 07:41:27 PM by Fourth Feline »
Re: Picks!
« Reply #35 on: March 25, 2009, 08:28:08 PM »
I liked the BKP picks a lot. I have been using 096 for a while and they work for me but I get through them quickly but that is probably cos I gig a lot.
Re: Picks!
« Reply #36 on: March 25, 2009, 08:31:30 PM »
I use those thinner nylon ones on acoustic but have never got on with them for electric for some reason. Feel weird, and I actually found them to give a duller tone than tortex..
Re: Picks!
« Reply #37 on: March 25, 2009, 08:36:35 PM »
I think you might be right there - I used tortex picks for years, but went back to nylon, I'll have to do a little test myself now :lol:
Re: Picks!
« Reply #38 on: March 26, 2009, 09:06:45 AM »
I use Tortex or Nylon Dunlops mostly 1.00mm or the next size down depending what I'm doing.
I'm using one with Homer Simpson on at the moment made by Grover Allman M size.  :D
