Author Topic: Driving a 4x12 Cab  (Read 5907 times)
James C
Driving a 4x12 Cab
« on: April 02, 2009, 01:52:08 PM »
Hi,
I'm getting rid of a Line6 HD 147, and with the money i'll be getting a new amp head, however i'm just wondering whether 30/40/50 watt heads would be powerful enough to drive a 4x12 (loaded with GT-75s) going off of the fact that my 6 watt Harly will scream through a v-30 i'd imagine so, but i thought i'd open it up to the floor.
Shortlist of amps are - Cornford Roadhouse 30 or 50, Bogner Alchemist HD40, ENGL Fireball 60w and Marshall VM2266 50w or JVM205H
Formerly "ManOnTheEdge"
  • Truly bad since 1972
Re: Driving a 4x12 Cab
« Reply #1 on: April 02, 2009, 01:53:08 PM »
er yes
« Reply #2 on: April 02, 2009, 02:00:00 PM »
4x12s sound also good at lower volumes. I ran a TinyTerror through a 4x12 and it was blasting!
G12T75s are not my favourite speakers though.
« Reply #3 on: April 02, 2009, 02:00:33 PM »
better mixed with another speaker
James C
« Reply #4 on: April 02, 2009, 02:09:45 PM »
I'm Starting to look at the Vintage Modern Amp as it should balance nicely with the sharper response (IMHO) of the GT12-75s and marshall recommend this pairing for more hard rock tones (as opposed to the greenbacks) although if i had the money i would load some V30s into the cab (x-pattern) cheers for the responses guys
« Reply #5 on: April 02, 2009, 02:49:51 PM »
VMs rock! Not sure how they match with G12T75s, but those amps are very much fun! I owned one for some time and enjoyed it a lot!
badgermark
  • Mm-hai!
« Reply #6 on: April 02, 2009, 04:13:38 PM »
I've blasted my 15 watt tiny terror head through a full stack before, sounded HUGE. Not much to contribute, just thought i'd boast.
« Reply #7 on: April 02, 2009, 05:48:52 PM »
Put a 5W Blackstar through an Orange 4x12 the other day loaded with Vintage 30s - sounded wicked - and very surprisingly loud.
« Reply #8 on: April 02, 2009, 06:24:06 PM »
ive driven a 4x12 with a tiny 1.2watt op amp before. not exactly load enough for a stadium, but not quiet
« Reply #9 on: April 02, 2009, 07:31:29 PM »
... but a higher power amp driving the speakers really does add some magic to the sound! I love the sound of a well-driven 4 x 12, get that air moving!!
That's not to take anything away from the 15W and lower power amps people have mentioned above - I'm sure these also sound fantastic through a 4 x 12!!
But in answer to the original question, yes, 30-50W is easily enough power to push a 4x12 depending on what speakers you have in there ;)
If you've got 4 EVM12L black labels (rated at 300W each), then good luck if you want any kind of speaker breakup (I dislike speaker breakup because I'm into more technical/articulate heavy stuff than bluesy music). If instead you have a quad of greenbacks and love power tube distortion, then 50W should do the job nicely :)
Roo
James C
« Reply #10 on: April 03, 2009, 07:24:06 AM »
Not really looking for too much speaker breakup as i'll be doing NWOBHM styled guitar, will probably get a 2x12 for bluesier applications if the need arises.
Cheers for all of the info guys
« Reply #11 on: April 03, 2009, 07:29:13 AM »
isn't that roughly half as loud as a 50watt blackstar? In terms of sound power levels and watts. 18watt marshalls are a pretty darn loud
« Reply #12 on: April 03, 2009, 01:47:13 PM »
I've no idea - never played one of the 50W Blackstars. Power ratings and sound pressure levels and percieved volumes really aren't very closely related. All depends on the circuit.
« Reply #13 on: April 03, 2009, 02:06:44 PM »
perceived volume is relative to frequency. I thought a 50watt head was 3db lower power than a 100watt head. but that doesnt mean its potentially half as loud. I thought like, a 10watt head sounds half as loud as a 100watt head to the human ear. i used to know all the maths involving sound power level. 20 time the logarithm of RMS over 2x10 squared. something like that. been a LONG time since i did acoustic mathmatics.
James C
« Reply #14 on: April 03, 2009, 02:13:59 PM »
Quote
Quote from: indysmith on Today at 01:47:13 PM
Quote from: Dmoney on Today at 07:29:13 AM
Quote from: indysmith on April 02, 2009, 05:48:52 PM
My brain is hurting
