Author Topic: Neck heavy guitar  (Read 6446 times)
Dazza1004
Neck heavy guitar
« on: April 06, 2009, 01:21:32 PM »
I've got a Washburn which I really like, the only thing that annoys me is it's neck heavy.
Daft question but would changing the position of the strap buttons help ?
I guess I could get a strap which is more grippy.
Re: Neck heavy guitar
« Reply #1 on: April 06, 2009, 01:31:55 PM »
Moving the strap towards the neck will help as it'll give it more angle.  A grippier strap is a must though.
« Reply #2 on: April 06, 2009, 02:11:47 PM »
What type of tuners has it got?  If they're big heavy Schallers or Grovers you could try swapping the metal buttons for pearloid or ebony ones, it saves a few ounces.
When I first got my Thinline Tele the headstock tended to dive towards the floor.... whilst rotating round my back.  With the pearloid buttons it's much better, and they match the scratchplate too.
« Last Edit: April 06, 2009, 04:04:36 PM by Philly Q »
« Reply #3 on: April 06, 2009, 03:07:31 PM »
dont underestimate this advice.. try it with different straps - thicker/grippier usually makes  a big difference!!
as for moving strap buttons - depends on the guitar so show us what you got
Dazza1004
« Reply #4 on: April 07, 2009, 01:15:20 PM »
here's the only picture I have of it
i will try a gripier strap in the 1st instance, cheers
« Reply #5 on: April 07, 2009, 01:57:26 PM »
well there is certainly no better place for the strap buttons than where they already are, very rare you get S-shaped guitars not balancing
lighter tuners may be a good suggestion.
Dazza1004
« Reply #6 on: April 07, 2009, 03:19:10 PM »
I do find it odd because the body is a big slab of (supposedly) mahogany
« Reply #7 on: April 10, 2009, 02:18:55 PM »
Will the tuners really make that much difference....a few tens of grams levering over that short distance...
Anyway
Only thing I can think, except the grippy strap (which is annoying cos it yanks your top about) is maybe...now no one think I'm crazy(er than usual) if theres space put some lead or similar in the control cavity.
« Reply #8 on: April 10, 2009, 02:40:27 PM »
Yeah, they can - made a massive difference on my Tele.
On a set of small-button Schallers it saves about 30g in total - not much maybe, but it works.
« Last Edit: April 10, 2009, 02:44:44 PM by Philly Q »
« Reply #9 on: April 10, 2009, 02:58:11 PM »
Fair enough. Never tried it.
jibidy
« Reply #10 on: April 13, 2009, 10:14:30 PM »
Grippy strap and a tight T-should is what you need. I find that my looser t's slip around and irritate my back to hell.
« Reply #11 on: April 13, 2009, 11:09:10 PM »
Besty advice I can give is for a "grippy" strap as has already been suggested. A think one for sure.
« Reply #12 on: April 15, 2009, 01:39:26 PM »
Bit off topic but did you mod that Fender to a double fat Strat or is that factory?
Dazza1004
« Reply #13 on: April 16, 2009, 10:38:22 AM »
thanks for all the input,
wrt to the strat, it's a lite ash, I bought a h-h scratchplate and stuck some HD's in there (it was already routed H-S-H).
eventually sold because it was buzzy (even after a full set up from Feline) and sounded like really tinny, even with the HD's
