Author Topic: Cheap A/B/Y pedal?  (Read 4090 times)
Adam.M
    • http://www.healeyamps.co.uk
Cheap A/B/Y pedal?
« on: April 06, 2009, 11:33:55 PM »
I'm after a cheap A/B/Y pedal, or even a kit i guess.
My amps now a Carlsbro 60TC, which like a plexi has two inputs for bass side and two for treble.
I've always thought it'd be cool to go through to amps, so i'm going to try going through two distortion pedals and seeing how i like it. Anyone tried it?
Could even have a totally dry side with just distortion and a slightly wet, less distorted side...
Hmm!
Denim n Leather
Re: Cheap A/B/Y pedal?
« Reply #1 on: April 07, 2009, 01:24:46 AM »
Morley has one that take two 9V batteries that's very good. It's quite transparent, well-built, and has silent switching.
Denim n Leather
« Reply #2 on: April 07, 2009, 01:26:10 AM »
http://www.morleypedals.com/daby.html :)
It's inexpensive, too.
hamfist
« Reply #3 on: April 07, 2009, 08:17:10 AM »
In the UK, a great place for ABY/loop/switching pedals is - http://www.redonionsolutions.co.uk/  - Top quality, true bypass, and very reasonably priced.
Tellboy
« Reply #4 on: April 07, 2009, 08:50:04 AM »
If you want REALLY cheap try the Behringer AB100 - has got level controls for each output.
Adam.M
« Reply #5 on: April 07, 2009, 10:36:42 AM »
I think red onion get the vote here, cheers hamfist!
hamfist
« Reply #6 on: April 07, 2009, 05:02:17 PM »
You're welcome.
I've got about 4 or 5 boxes/pedals  from TJ at Red Onion, and they have all been top notch. Thoroughly recommended.
« Reply #7 on: April 07, 2009, 05:57:31 PM »
I think the issue with those kind of pedals is the Y option, to get the signal split and both at the same power.
If I were to get an ABY (which I really should do) I would go with the Radial, but I just need to justify the price. It is a bit too much money really.
« Reply #8 on: April 07, 2009, 07:26:35 PM »
I was going to recommend red onion, but then I forgot to and turned off my computer :lol:
JamesHealey
« Reply #9 on: April 08, 2009, 10:40:50 AM »
I'll make one for you.  :D
  • Truly bad since 1972
« Reply #10 on: April 08, 2009, 02:42:59 PM »
you have a schematic or drawing for the a/b/y
