Author Topic: Just bought a Brown Sugar set for my Blade, but it has a VSC boost circuit.....  (Read 3730 times)
gibsongaz#1
Can I still change them into the Blade and use the circuit?
iirc the VSC is a circuit board in the control cavity.  the pickups are still normal pickups so a swap should be possible.   Its only really if they had built the circuit into the pickup itself that you would have issues
gibsongaz#1
Great! Thanks
gibsongaz#1
Fitted and sounds great! Thanks for all your advice! I used a tip from Guitar and Bass Mag by fitting spade connectors - worked a treat and sooooo much easier!  8)
