Author Topic: Wiring 2 buckers to 3-way switch and then directly to jack?  (Read 20727 times)
Re: Wiring 2 buckers to 3-way switch and then directly to jack?
« Reply #30 on: April 24, 2009, 08:18:28 PM »
So then its probably working as it should? :?
Well, yes and no.... it sounds like it's basically working, but if it sounds bad there must be something wrong.
Madiac
« Reply #31 on: April 24, 2009, 08:48:11 PM »
Actually after some more playing i think it sounds as it should  :roll:
I guess my ears just had to adjust, i hadnt played it for a while while it was on the "workbench", sound is all fine, but its hard to tell really if it used to be better or not, i cant remember for sure haha! It sounds good anyhow  :lol:
Well, thanks for the help guys, i learned a bunch from this, but from now on im sticking to the 4 pot gibson set-up, i like it that way. You dont start missing it until you dont have it anymore  :roll:
Ill probably change it back at some point, any tips for getting the grounding spray back where the switch was? Just spray some over that area?
« Last Edit: April 24, 2009, 08:57:36 PM by Madiac »
« Reply #32 on: April 24, 2009, 09:26:47 PM »
Yeah, or try the brush-on stuff from StewMac:
http://www.stewmac.com/shop/Electronics,_pickups/Supplies:_Shielding/Conductive_Shielding_Paint.html
