Started by Sifu Ben, April 22, 2009, 07:26:12 PM
Quote from: Philly Q on April 23, 2009, 12:07:48 PMI hate the slot-headed screws too, the screwdriver slips out of the head too easily. I always replace them with Phillips ones.
Quote from: Philly Q on April 23, 2009, 12:07:48 PMI don't usually use the BKP springs, they're too long (IMO) unless the pickup has long legs.
Quote from: Philly Q on April 23, 2009, 12:07:48 PMAnd I hate the slot-headed screws too, the screwdriver slips out of the head too easily. I always replace them with Phillips ones.
Quote from: FELINEGUITARS on April 24, 2009, 02:38:37 PMHave a look at thishttp://www.stewmac.com/shop/Tools/Special_tools_for:_Electronics/Humbucker_Helpers.html
Quote from: Philly Q on April 25, 2009, 12:19:17 PMQuote from: FELINEGUITARS on April 24, 2009, 02:38:37 PMHave a look at thishttp://www.stewmac.com/shop/Tools/Special_tools_for:_Electronics/Humbucker_Helpers.htmlThe only reservation I'd have about that device is that it'll only work if the screws are longer than the Humbucker Helper itself - maybe they should make it in two different sizes so you can also use it with shorter screws?
Quote from: Ivan on April 25, 2009, 07:12:47 PMQuote from: Philly Q on April 25, 2009, 12:19:17 PMQuote from: FELINEGUITARS on April 24, 2009, 02:38:37 PMHave a look at thishttp://www.stewmac.com/shop/Tools/Special_tools_for:_Electronics/Humbucker_Helpers.htmlThe only reservation I'd have about that device is that it'll only work if the screws are longer than the Humbucker Helper itself - maybe they should make it in two different sizes so you can also use it with shorter screws?Varying sizes would be good.But I think the intended use for that tool is for you to depress the spring before putting it on. Like an extra hand for holding the spring down while you fiddle with the other bits.
